What's tha diff?
Old Jul 17, 2003 | 05:01 AM
CTR94Joes's Avatar
Default What's tha diff?
What's the difference between a LS motor and a B20 motor, I know that the B20 is bigger b/c of the 84mm bore, but what's the big difference or are they the same motor(meaning same block etc...) and the only difference it that the B20 has a 84mm bore to make it a 2.0l?
Old Jul 17, 2003 | 08:17 AM
Kataku2K3's Avatar
Default Re: What's tha diff? (CTR94Joes)
It's basically the same block but they are NOT from the same cast... If you ever look at B20B/Z the casing looks a lil weaker than that of a B18C but for the most part they are kind of similar... Then take a look at an LS and you'll see what I mean, the reinforcements on the front look like nothing... BUT the good thing about the older B18A blocks is they still came with a PCV "box" system the B18B and B20B/Z do not... It doesn't really matter but it's something I like if you don't plan on running an external catch can on an LS/CRVTEC... They do happen to run the same crank, same nonVTEC water pump, etc... But for the actual casing from the outside it may be a lil stronger but the sleeves are weaker due to their one piece design... Hope this helps, Latez
rick_rabies
Jun 11, 2009 07:06 PM
xism
Jan 10, 2007 05:47 AM
NA JDM GSR
May 15, 2006 01:21 PM
SpeedMonkeyRacing
Oct 1, 2003 12:57 PM
Thats-so-Ls
Sep 19, 2001 04:56 PM
