compression is down
Old Jul 16, 2003 | 12:42 PM
juicedricer's Avatar
Default compression is down
ok i did a compression test about 2 months ago when i did my water pump. then it was at 185-170-170-170........... now i recently did one because the car hasnt been pulling the times it was in the beginning of the season. now, 185-175-165-155. can anyone tell me where i am loosing compression at? is it the piston rings? or maybe could it even be a leak in the headgasket that could cause it??? also if it is the piston rings what procedure would i go through to replace the rings since i am replacing rings should i just get a set of CTR pistons or an aftermarket set???
Old Jul 16, 2003 | 01:56 PM
Default Re: compression is down (juicedricer)
come on anyone???????any ideas???
Old Jul 16, 2003 | 01:59 PM
non-VTEC's Avatar
juicedricer.......with this user name I'm going to assume you are spraying that engine with stock internals and you are wondering why you are loosing compression.......mmmmmmmmm.......think about it for a second.....
while the engine will take nitrous for a while you are defiantly speeding up the wear process by using it. first things to go are usually rings and valves......
good luck
Old Jul 16, 2003 | 02:05 PM
Default Re: compression is down (non-VTEC)
thing is the nitrous is not even installed yet i was waiting until i replaced the block with a new head to run it. and send the old head to a machine shop to get a valvejob n cams installed ect ect.
but the car does get a heavy beat down when i drive it at night sometimes.
Old Jul 16, 2003 | 02:11 PM
non-VTEC's Avatar
how many miles on the engine?
maybe you shouldent beat it down so hard.......are you sure your doing the compresison test correctly? engine warmed up, ECU fuse pulled out, press the gas pedal to WOT, crank 5-6 times......
Old Jul 16, 2003 | 02:29 PM
hmmmm............didnt do the ecu fuse thing ill try that tonight maybe n see again............i have just been edgey since the last 6 passes down the track i have not been able to crest even a 14.9 and b4 the waterpump isntall i was running 14.7-14.9s all day.......my mph is down by 3 and my tiems are at best 15.1 consistant. the 60' and rt are all the same
Old Jul 16, 2003 | 05:01 PM
Deluzional's Avatar
You didnt pull the Ecu fuse??? Then that means, that fuel should have been squirting you, thats the reason you pull that fuse..right????
Old Jul 18, 2003 | 01:18 PM
Default Re: compression is down (Deluzional)
its a headgasket leak i just found out today during a leakdown test. so now i am currently looking for a complete ls head in the nj/ny/pa area. anyone have one for sale?????please im me.................
Old Jul 18, 2003 | 04:10 PM
I HAVE SEX WITH MY MOTHER
this comment was made by randy goetz and his number is 908-295-4309
he was the oen who almost got me kicked off b4 and i dunt like important questions i ask being looked as shiet. he is my manager go ahead n call.
Modified by juicedricer at 6:00 PM 7/18/2003
Old Jul 18, 2003 | 04:41 PM
patdemps's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">how many miles on the engine?
I am doing a compression test this weekend. I will make sure and do this. Thanks for posting it. Also, what does WOT mean? Thanks
Old Jul 18, 2003 | 04:44 PM
haggar's Avatar
Default Re: compression is down (patdemps)
WOT = Wide Open Throttle
Old Jul 18, 2003 | 04:46 PM
Fkned2003's Avatar
why do you need a new head, is damage unrepairable? If the motor was running somewhat ok it should be fixed by resurfacing it. did it torch the deck?
Old Jul 18, 2003 | 05:02 PM
Default Re: compression is down (Fkned2003)
what i am doing with the old head is sending it out for a P&P job and 5 angle and buying maybe a set of EF-1 cams or either crower. that way i will have the head being done while i can still drive. only car i have to drive.
Old Jul 18, 2003 | 05:04 PM
Fkned2003's Avatar
where you sending it ,if you dont mind me asking?local?
Old Jul 18, 2003 | 05:42 PM
yea my freind refered to me fisher machine shop in edison. i think the rate is 250 for a dohc motor with P&P and 5 angle not bad for that price. but i have heard for certain cams is good to get it ported for the spec of the cam so now i will have to choose what cams i am getting.
Old Jul 18, 2003 | 05:51 PM
Fkned2003's Avatar
have to admit cant beat that price,hell considering most shops charge $175-225 for a valve job alone dont know how he's surviving on that price.
Old Jul 19, 2003 | 12:07 AM
well thats the price i was told so we'll see when i get there i am going with my freind who knows the guy personally too. my freind (also a honda-tech *****) got his head decked there and ported polished and port matched the manifold and TB there also. so if his car runs 13s all motor like we expect on street tires then definately he will get my business.
lilo_goki
Feb 18, 2009 01:56 AM
honda305
10
Feb 15, 2009 06:34 PM
MAX PAYNE
Jul 23, 2007 12:29 PM
juicedricer
Jul 16, 2003 02:10 PM
98civicEX
Apr 8, 2003 10:55 AM
