White Stuff on O2 Sensor....
Old Jul 15, 2003 | 12:36 PM
Unjockable's Avatar
New User
Default White Stuff on O2 Sensor....
i recently took out the o2 sensor from my test pipe and there was white **** all over it. it wiped off easily with a rag. is this a bad thing?
Old Jul 15, 2003 | 03:09 PM
I Want An Si's Avatar
Default Re: White Stuff on O2 Sensor.... (Unjockable)
quit whacking off in your exhaust!!!
but seriously.... i believe it means youre running lean
Old Jul 15, 2003 | 03:48 PM
preluder's Avatar
Default Re: White Stuff on O2 Sensor.... (d16a)
ahahahahahahahahaha
Old Jul 15, 2003 | 04:48 PM
Unjockable's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16a &raquo;</TD></TR><TR><TD CLASS="quote">quit whacking off in your exhaust!!!
but seriously.... i believe it means youre running lean</TD></TR></TABLE>
lol...anyway i can stop it from running lean? i know i dont want to run lean or rich but is running lean better then running rich?
Old Jul 15, 2003 | 06:40 PM
poison's Avatar
No, it's not good to run either. You want to run stoich. Running lean can cause back fire and running rich can foul up and make O2 sensors/spark plugs go bad.
Old Jul 15, 2003 | 07:26 PM
Unjockable's Avatar
New User
Default Re: White Stuff on O2 Sensor.... (poison)
what's the first thing i should do to make my car run stoich?
Old Jul 15, 2003 | 07:46 PM
ScottEK's Avatar
Was the white stuff on the sensor or the threads.
New o2 sensors have anti-seeze coated on the threads.
Old Jul 16, 2003 | 10:21 AM
Unjockable's Avatar
New User
Default Re: White Stuff on O2 Sensor.... (beta13)
it's on the sensor.
Old Jul 16, 2003 | 10:32 AM
Quik Chris's Avatar
How about this.... instead of making asumptions off the O2 sensor, check your plugs to see if they're white too. That will tell you if you're lean or not. O2 sensors aren't typically used to make sure the car is running the propper A/F ratio-- partly beacause they're inside the cat which gets into the 1500-2000°F range, and alters the chemical proporties of the exhaust.
Old Jul 16, 2003 | 11:46 AM
BI8B's Avatar
i'm having the same problem
Old Jul 16, 2003 | 04:28 PM
Unjockable's Avatar
New User
Default Re: (BI8B)
i already check the spark plugs before that and it's also white...
Old Jul 16, 2003 | 04:48 PM
mmuller's Avatar
Mad Scientist
Default Re: (Unjockable)
definetely lean, whats your setup?
Old Jul 16, 2003 | 11:18 PM
Unjockable's Avatar
New User
Default Re: (mmuller)
i have a 96 hatch with a LS motor. Basic bolt ons for now. intake, header, straight pipe, exhaust.
Shonn
Oct 16, 2006 04:29 AM
Jewsol
Mar 1, 2004 07:08 AM
spencedogg
27
Nov 20, 2003 04:20 PM
ramz7887
Jul 19, 2003 10:48 AM
