Internal Wastegate questions
Old Jul 13, 2003 | 09:08 PM
Sohc Driver's Avatar
Default Internal Wastegate questions
I have a 16g Mitsubishi turbo, and the stock internal wastegate is 10psi. If all i want to run is 5psi of boost..how will I be able to accomplish this?
Khoi
Old Jul 13, 2003 | 09:25 PM
_Endless_'s Avatar
Default Re: Internal Wastegate questions (Sohc Driver)
you have to change internal wastegate unit to one with a boost level you want coz you can't lower the boost from the what the stock setting is. you can go higher but not lower.
Old Jul 13, 2003 | 09:26 PM
Flamenco-T's Avatar
nope
stan
Old Jul 13, 2003 | 09:29 PM
Default Re: Internal Wastegate questions (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">nope
stan</TD></TR></TABLE>
Nope?? To what...
Khoi
Old Jul 13, 2003 | 09:30 PM
Flamenco-T's Avatar
Sorry, I meant No, it's not possible, you need to change out the spring on the wastegate...
Old Jul 13, 2003 | 09:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, I meant No, it's not possible, you need to change out the spring on the wastegate...</TD></TR></TABLE>
Can you lead me in the right direction..as to where i can find an internal wastegate compatible to my DSM 16g turbo?
Khoi
Old Jul 14, 2003 | 04:55 AM
bump
Old Jul 14, 2003 | 05:31 AM
2DXtreme's Avatar
New User
this is what i did
http://zoogle.zapto.org/wastegate.jpg
Old Jul 14, 2003 | 09:10 AM
Default Re: (2DXtreme)
i rather just replace the wastegate with a 5-6psi...i don't want to modify the current one...will any internal wastegate work? Or do i have to find a specific one for my DSM 16g....please any info is appreciated.
Khoi
Old Jul 14, 2003 | 09:32 AM
Charlie Moua's Avatar
Well I though that 16G came with a actualtor arm to adjust the boost like the 15G and 18G turbos?
Well you can always get a boost controler.
Old Jul 14, 2003 | 09:35 AM
Default Re: Internal Wastegate questions (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">Well I though that 16G came with a actualtor arm to adjust the boost like the 15G and 18G turbos?
Well you can always get a boost controler.</TD></TR></TABLE>
I thought you can't lower boost lower than the wastegate?
Old Jul 14, 2003 | 09:45 AM
falcongsr's Avatar
What is this crap?
that arm doesnt really control boost. the characteristics of the spring ( K, spring constant) control at what pressure the WG will open. the arm length just determines how much force is applied before the flapper opens up. therefore you can only raise boost with the arm length. and its likely to cause spiking if you try to raise boost that way.
you have to change out that spring in the actuator if you want to lower boost. you can buy actuator assemblies that are lower psi , but not down to 5psi. trust me, i looked.
in short - internal wastegates suck.
Joe - the resident internal wastegate understudy.
Old Jul 14, 2003 | 11:40 AM
Default Re: Internal Wastegate questions (falconGSR)
can i replace my wastegate actuator with anykind of actuator..or does it have to be specific to my turbo?
Khoi
Old Jul 19, 2003 | 07:49 PM
spooned out's Avatar
i got mine from greddy actually a direct dealer that gets greddy parts and just got a actuator for a 18G turbo but had to do alittle mod to it but seems to work
Old Jul 20, 2003 | 11:31 AM
Default Re: (spooned out)
ehh....I decided to just get rid of the internal wastegate and run a Tial external......its ultimately the better choice...
Khoi
a1320honda
Feb 25, 2008 06:21 AM
T9U4ReBgO
Nov 12, 2007 01:19 AM
eg crunkmonster
Jul 24, 2006 05:13 AM
AutoEuphoria
Sep 30, 2004 06:36 PM
Killer_B
Apr 16, 2004 12:16 PM
