dual 2 ohm voice coil 12" woofer and 500s fosgate amp... heLLP!
okay any how...
i got a dual 2ohm voice coil woofer... and im running it with a fosgate 500s amp...
right now i have it hooked up in a series... (4ohms)... and i kno the 500s amp can make more power at 2ohms... but how could i wire both coils to get 2 ohms?
or if possible... can the 500s amp handle 1ohm? (parallel setup...)
how would i get the max power out of my amp using just one woofer... with dual 2 ohm coils...
The only way you can wire that sub is either a 4 ohm or 1 ohm load. I would not recommend connecting a 1 ohm load to that amplifier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laosfu »</TD></TR><TR><TD CLASS="quote">what if i ... just wired each coil to a channel.. ?</TD></TR></TABLE>i have thought about this, and since i have thought about it i think it is safe to say it is utter rubbish
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warric_k »</TD></TR><TR><TD CLASS="quote">you won't always get the same amount of power, and you may run into cancellation between frequencies... </TD></TR></TABLE>
Huh
He is talking about a single sub. What cancellation?
Huh
Why did you raise you false floor so high? Is you spare still available? You used up the whole trunk with MDF with only 1 sub. With all that weight you can redue you whole setup and stilll have room. Take a look at my systems it can give you a idea.
What kind of car do you have?
http://members.sounddomain.com/royan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laosfu »</TD></TR><TR><TD CLASS="quote">i didnt use mdf... and i dont care about my spare... and my set up probably weighs less than yours... </TD></TR></TABLE>
So you didn't use mdf for your setup. Whatcha use plywood or particle board?
All I'm saying is that you can still have room with only 1 sub and amp. But it's your car you laosfu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warric_k »</TD></TR><TR><TD CLASS="quote">he was talking about running left channel to one voice coil, right channel to the other.</TD></TR></TABLE>
You care to explain how your going to get cancelations. Left channel is the same as the right. both are in phase.
