T4
Old Jul 10, 2003 | 04:55 AM
93H22ACX's Avatar
Default T4
What do you guys think of a straight T4 on a built H22? The T4 has an A/R of 1.10
WHP target is 500whp with 850cc injectors.....I dont think my T3/T04B will be sufficient
Old Jul 10, 2003 | 04:58 AM
Tinker219's Avatar
Default Re: T4 (95PRELUDEVTEC206)
lag, lots of it.
if you get a smaller turbine, and at LEAST a 60-1 configuration, then you should be able to meet your goals.
Old Jul 10, 2003 | 05:09 AM
onetwothree's Avatar
Default Re: T4 (Tinker219)
Your redline isn't high enough for that big of a turbine housing. Get the .82a/r
Old Jul 10, 2003 | 05:20 AM
autoEXturbo's Avatar
i made 500whp on my T4 60-1 .70a/r .58exhaust
Old Jul 10, 2003 | 06:19 AM
93H22ACX's Avatar
Default Re: T4 (autoEXturbo)
Thanks for your replies
Old Jul 16, 2003 | 03:04 AM
ID_ten_T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoEXturbo &raquo;</TD></TR><TR><TD CLASS="quote">i made 500whp on my T4 60-1 .70a/r .58exhaust</TD></TR></TABLE>
what engine is this on? also, how much boost are you running to get the 500whp? and, how long does it take to spool up? thanks.
Old Jul 16, 2003 | 03:30 AM
MiraiZ's Avatar
Default Re: T4 (ID_ten_T)
I would think that on an H22A, itdhould be fine....
Old Jul 16, 2003 | 04:12 AM
ekb18c's Avatar
This is for the street? Then it might be a little too laggy for you, try .72 a/r.
For track? Then it will be pretty good w/ 2 stepper.
Old Jul 16, 2003 | 06:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ID_ten_T &raquo;</TD></TR><TR><TD CLASS="quote">
what engine is this on? also, how much boost are you running to get the 500whp? and, how long does it take to spool up? thanks.</TD></TR></TABLE>
GSR, 23psi, spooled fully by about 5k rpm.
Old Jul 16, 2003 | 08:21 AM
kpt4321's Avatar
1.10 is so huge, you would have trouble making ful boost at a usable rpm at the track, without nitrous or such.
You probably want closer to .83 (Is that right?) for a track car, and closer to .72 for a street car.
cleanej2
Mar 8, 2007 05:06 AM
ProPerformance
Sep 5, 2006 06:25 AM
boostedfe3
May 8, 2005 10:02 AM
redboost10
Oct 24, 2003 09:03 AM
BoosterChair
Apr 13, 2003 09:18 PM
