need help fast!!!!!!!!111
I assume by remote you mean "remote power enable" - is it next to the main power & ground terminals? The main power comes from the battery, but the remote enable comes from the head which only turns the amp power on via an internal relay when the head unit is on. You hsould be able to find a power output from the head that you can run a wire to the amp to enable this function. If you just want to get it going to test it, just jump a wire between the power & remote terminals on the amp. Remember you don't want to leave it like this as the amp will powered <U>all the time</U> - even when the ignition is off.
