need help fast!!!!!!!!111
Old Jun 28, 2003 | 11:22 AM
vteckiller's Avatar
Default need help fast!!!!!!!!111
on the amp there is a connection for the remote. i need to know what that has to be connected to if i have the stock face, to run the subs. thanx
Old Jun 28, 2003 | 12:13 PM
D'Ecosse's Avatar
Default Re: need help fast!!!!!!!!111 (vteckiller)
I assume by remote you mean "remote power enable" - is it next to the main power & ground terminals? The main power comes from the battery, but the remote enable comes from the head which only turns the amp power on via an internal relay when the head unit is on. You hsould be able to find a power output from the head that you can run a wire to the amp to enable this function. If you just want to get it going to test it, just jump a wire between the power & remote terminals on the amp. Remember you don't want to leave it like this as the amp will powered <U>all the time</U> - even when the ignition is off.
Old Jun 28, 2003 | 04:10 PM
darkvibe's Avatar
you could always wire it to the accessory fuse under the dash.
White Boy Hatch
18
Jan 4, 2011 10:05 PM
White Boy Hatch
Audio / Security / Video
Jan 4, 2011 08:19 AM
SIC_jdm_da9
Apr 23, 2007 10:33 AM
Understeer
Aug 23, 2002 03:04 PM
haloseven
Mar 12, 2002 07:21 PM
