Does a lightened flywheel make power?
Old Jul 25, 2001 | 10:52 PM
VaporTrail's Avatar
New User
Default Does a lightened flywheel make power?
Here's a before/after dyno run - judge for yourself
Blue (#27) - stock flywheel
Red (#28) - ACT lightened OEM flywheel
[Modified by VaporTrail, 2:53 AM 7/26/2001]
Old Jul 25, 2001 | 10:54 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Does a lightened flywheel make power? (VaporTrail)
Old Jul 25, 2001 | 11:02 PM
Mr Integra's Avatar
New User
Default Re: Does a lightened flywheel make power? (Arturbo)
i vouch for that... it doens't make power, but free up power that was currently lost..
Old Jul 25, 2001 | 11:04 PM
boomslang's Avatar
How the heck do you get 213 hp @ 7 psi out of a sohc motor? That can't be normal...
Old Jul 25, 2001 | 11:23 PM
TypeRollin's Avatar
Does it help you rev up faster?
Old Jul 25, 2001 | 11:24 PM
Ricehornet's Avatar
also if you notice the gains are pretty even throughout the rev band. pretty
It frees up power because more of the TQ actually gets to the wheels instead of being spent to spin it.
I also assume that the car revs faster with the increase in WTQ, and the lessened rotational inertia of the flywheel.
all this from 12lb lbs eh. i wonder what the 8lbs guys are making.
Did you get the weight for the stock flywheel by any chance?
Old Jul 25, 2001 | 11:26 PM
VaporTrail's Avatar
New User
Default Re: Does a lightened flywheel make power? (Inlinefour)
I was surprised myself. But he brought the car to me completely stock, with about 1500 miles on the clock. Car subsequently ran a 14.0@100mph on slicks - this was about a year ago. One thing you have to remember is that it's not no silly small GReddy turbo, it's a full t3/04 and adequately sized intercooler. The dyno doesn't lie, and neither do I
Old Jul 25, 2001 | 11:28 PM
VaporTrail's Avatar
New User
Default Re: Does a lightened flywheel make power? (Ricehornet)
If I'm not mistaken, the stock flywheel weighs approximately 19lbs. The car did rev up noticably faster, especially rolling into 2nd gear, where traction is not as much an issue.
Old Jul 25, 2001 | 11:34 PM
boomslang's Avatar
213 hp @ 7 psi on a sohc. Boy that sure is a kick in the nuts to almost all the turbo prelude owners out there.
Old Jul 25, 2001 | 11:42 PM
VaporTrail's Avatar
New User
Yes, but the torque isn't there on the SOHC. Interesting point though
Old Jul 26, 2001 | 07:55 AM
Smashback's Avatar
Won't matter since a Civic weighs how much? And a Lude? love those SOHC Civics baby !!
Old Jul 26, 2001 | 09:36 AM
Ubermensch's Avatar
Default Re: Does a lightened flywheel make power? (mplex2000)
I didn't realize anyone questioned the fact that less rotational mass at the flywheel improved power to the wheels
What I question is whether or not the rpm stays in region of the band where you have boost when you shift, or if it drops you out of boost?
Old Jul 26, 2001 | 10:37 AM
Ricehornet's Avatar
Default Re: Does a lightened flywheel make power? (Ubermensch)
You mean cause the wheel has little inertia that it slows downs quicker than stock?
From the videos i've seen it appears they shift fast enough (and you notice the needle fall fast) but still in a good area. Also, if you were boosted wont you have more room for it to fall since full boost is made in the mid range, not just up top? Not saying you want to fall that far, but you wont have to worry about "falling out of vtec, or secondaries"
Old Jul 26, 2001 | 11:02 AM
Smashback's Avatar
Yep .. mine sure doesn't fall too far! It's niiiice.
Old Oct 11, 2002 | 11:11 PM
Midwestrider's Avatar
(Rise from the dead.. )
I am curious to what the power output would be if say a Clutchmaster flywheel was used.
I am looking for a new flywheel/clutch setup for my turbo app.
Old Oct 11, 2002 | 11:47 PM
*Boostwerks*'s Avatar
Default Re: Does a lightened flywheel make power? (Midwestrider)
holy **** this thread is old
Old Oct 12, 2002 | 12:13 AM
turbocoupe's Avatar
Default Re: Does a lightened flywheel make power? (Bryson)
Old Oct 12, 2002 | 12:14 AM
PrecisionH23a's Avatar
My nuts are made of steel and i kick back! hehe. Remember, every little hp gain helps out in the longrun... thanks for the info, even though it is months old i still learned something new today.
Old Oct 12, 2002 | 02:42 AM
turbopanda's Avatar
Default Re: Does a lightened flywheel make power? (GudeH23a)
wow.. i thought it wasn't possible to reply to archived posts...
Old Oct 12, 2002 | 06:45 AM
POLLO's Avatar
Default Re: Does a lightened flywheel make power? (turbopanda)
Well, since Nathan brought this thread back from the dead.....
John, I meant to call you yesterday.... at what rpm that SOHC was able to reach full boost ? So far I was looking for a t3 .45/.63 but now Im wondering about a t3/t4 turbo like this ? Im gonna be pushing upwards to 20psi but im more concerned about the lag. CALL me now on the hotline.
92B20VTEC
Jul 18, 2009 09:26 AM
ELITE 350Z
Apr 14, 2004 12:57 AM
integra-modder
Oct 7, 2002 02:04 PM
mattL
Apr 19, 2002 05:40 PM
HX_Guy
Jul 28, 2001 02:05 PM
