tie rod boot install
Old Jun 26, 2003 | 11:28 AM
94TealCivic's Avatar
Default tie rod boot install
I was just wondering what's the process of installing the boot. I have never done this before but seems straight foreward but I want to make sure I do this correctly. First, I need special grease for it correct? I want to know how you did it and how much grease to put in. I would really appreciate any responses, thanks!
Old Jun 26, 2003 | 11:31 AM
JV's Avatar
JV
Who?
Default Re: tie rod boot install (94TealCivic)
Remove the retaining ring, remove the old boot, pack the new one with grease, reinstall...
Old Jun 26, 2003 | 11:32 AM
Default Re: tie rod boot install (JV)
What kind of grease? How much...until it starts dripping out??
Old Jun 26, 2003 | 11:35 AM
JV's Avatar
JV
Who?
I used an "all purpose" grease that was at my friends shop. Just pack it to the top and squeez some out if it's too much...
Old Jun 26, 2003 | 11:39 AM
Thanks JV for answering my stupid question
Old Jun 26, 2003 | 11:45 AM
JV's Avatar
JV
Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94TealCivic &raquo;</TD></TR><TR><TD CLASS="quote">Thanks JV for answering my stupid question </TD></TR></TABLE>
It's not stupid.
I had to replace both my lower balljoint and tie rod boots after i did my swap. Now that's stupid.
Damn ball joint forks...
Old Jun 26, 2003 | 02:01 PM
hellas's Avatar
how are you supposed to remove the old boot? mine dont have rings on them, and i cant take the old one off. only thing i can think of is a gasket scaper...is there an easier way?
Old Jun 26, 2003 | 08:08 PM
Default Re: tie rod boot install (hellas)
Well you can cut it if nothing else works. That's if you need to replace it anyway. But it should have a clamp at one end, just take it off and undo the nut at the other end and the boot slides right off.
kornerk12
Apr 1, 2007 04:34 PM
Vitesse
Jul 20, 2006 09:50 AM
the soL that could
Suspension & Brakes
13
Mar 25, 2006 09:22 AM
DrivinVtec
Feb 5, 2006 10:02 PM
ep3minivan
12
Apr 14, 2004 05:31 PM
