Need Help with Tranny
Old Jun 25, 2003 | 06:07 PM
TurboBoostinSI's Avatar
Default Need Help with Tranny
ok heres the deal. i have a 00 si turbo charged, and if im racing or driving fast and shift into 3rd gear it grinds. i know that honda has had problems with there 3rd gear in b series tranny. do you think its the syncro or i need a new clutch. if it is the syncro had hard would it be to replace it myself.
Old Jun 25, 2003 | 07:05 PM
tilt's Avatar
Default Re: Need Help with Tranny (TurboBoostinSI)
generally when one gear grinds it is the synchro. when all grind it is usually the clutch. Before you go dropping the tranny, you might want to try some better tranny fluid like redline mtl/gm synchromesh/ honda mtf and see if it helps.
Old Jun 26, 2003 | 05:52 PM
Default Re: Need Help with Tranny (tilt)
how hard it is to replace the synchros.
Old Jun 26, 2003 | 05:57 PM
AutoXsi2000's Avatar
dang you too have problems with tranny. sucks.
Old Jun 26, 2003 | 07:19 PM
Dgr8wun's Avatar
its not that hard... just buy the manual and follow the directions, i've rebuild a few already and its worth it ($250 for the synchro). better than buying a used one and finding out the synchros are bad..
mikej94civex
Mar 10, 2010 04:47 PM
TurboGoKart
Jun 7, 2006 04:34 AM
GWInquisitor14
Oct 15, 2004 10:06 AM
stilzx61
Feb 14, 2004 01:28 AM
Fr0m4311
Apr 7, 2002 09:31 PM
