New Distributor >> Runs Like Shit
I got a enw distributor and new coil today for my 93 coupe. It runs like **** now. When I accelerate it feels like the engine is hesitating till about 3k rpm.
Does anybody know what my problem could be, does it have anything to do with the distributor?
I had it done by my mechanic, he said that my timing belt was off by two or three teeth, which i will fix as soon as i have time. But it never ran this bad before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chainsaw »</TD></TR><TR><TD CLASS="quote">take the distributor off and spin the shaft 180, then put it back on and see if it helps.</TD></TR></TABLE>
exactly.
exactly.
Well it turned out that when my distributor broke it made the timing belt jump a tooth so the timing belt was off. I fixed it and now it runs better than ever, even better than before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve_s »</TD></TR><TR><TD CLASS="quote">Well it turned out that when my distributor broke it made the timing belt jump a tooth so the timing belt was off. I fixed it and now it runs better than ever, even better than before.
that makes no sense. How does a broken dist make the timing belt jump
</TD></TR></TABLE>that makes no sense. How does a broken dist make the timing belt jump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
Yes, A friend of mine who works at an Acura dealer says it happens all the time. The worst case of a siezed dist. shaft snapped a timing belt.
They didn't realise it was the dis. that was siezed until after they replaced
the timing belt and the engine still wouldn't spin.
</TD></TR></TABLE>Yes, A friend of mine who works at an Acura dealer says it happens all the time. The worst case of a siezed dist. shaft snapped a timing belt.
taguchi09
Jun 11, 2011 04:52 PM
