oil tap.
Old Jul 24, 2001 | 04:38 PM
quikrpm'z's Avatar
Default oil tap.
for a b18b1, wheres a good place to tap for an oil pressure gauge? Im already using the reg oil tap for the turbo. Im already using a T, and would rather have a separate tap, also what is necessary to do the tapping?
[Modified by quikrpm1, 5:39 PM 7/24/2001]
Old Jul 25, 2001 | 11:28 AM
keithv's Avatar
Default Re: oil tap. (quikrpm1)
To do the oil pressure guage install, I just used a T fitting, some nylon tubing (to get the T place on the firewall), and the presssure gauge. I'm not sure where to tap off for the guage with the turbo having a tap allready....
Old Jul 25, 2001 | 12:15 PM
Speed PHreak's Avatar
Dude, I would suggest, using 2 Ts and coming off of the factory oil send hole. Run a peice of SS line back to the 2 Ts at the firewall. Just join the Tees like this ( TT ). You'll have four holes to use.
1 coming from your block
1 for the oil line to your turbo
1 for your stock O/P sender
1 for your after aftermarket sender.
~steven
TravisBiggie
Aug 20, 2013 07:48 PM
BlueShadow
Apr 11, 2005 01:17 PM
W O T
Jan 29, 2005 08:01 PM
Nextelbuddy
Jul 13, 2003 07:44 PM
nukem384
Mar 5, 2003 06:11 PM
