Turbo oil feed line/oil pressure gauge
Hello
Couple weeks ago I had an oil pressure issue and I finally fixed it.
I get 80psi cold with my oil pressure hooked up right to the back of the block. Today I reinstalled my turbo oil feed line in the back of the block, to the turbo. On this line, I have a brass T fitting with the oil pressure gauge hooked up (this is about a foot before the turbo) With this hooked up, I see 40 psi cold.
Is this a problem? Or is it okay as is? My builder is telling me to install the T at the block instead of down the line like it is now.
Thoughts?
Thanks!
Thoughts?
Thanks!
It's wU to the sOLdiEr!
Re: Turbo oil feed line/oil pressure gauge
you do what your builder is telling you on this
the T needs to come off where the oil pressure switch is at and not T off your oil pressure gauge. if you have a picture to better explain what your doing, please post it.
cantaffordaccord
02-21-2010 09:52 PM
