Compression test results
I used a craftsmen compression tester and came up with the following. Seems ok for an engine with 38850 miles and in need of a valve adjustment.
#1 - 215
#2 - 230
#3 - 235
#4 - 230
Any reason why number one would be the lower of the cylinders or do these numbers seem alright? Also, when I checked the #2 I cranked about 5-6 times at WOT and first only came up with 197, then after checking the remainding cylinders I went back to #2, cranked 5 times again and came up with a final result of 230. Everything seem ok?
#1 - 215
#2 - 230
#3 - 235
#4 - 230
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">why don't you try number one again?</TD></TR></TABLE>good point, although I figured it seemed to be in spec. I'll try again though to see what happens.
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Did you guys crank it 7 times with the throttle plate opened? You're supposed to nail it seven times and it should go up at a even and steady pace. I cranked it 4 times without the throttle opened and i hit 250's and 260's all the way up.
