Compression test results
Old Jun 17, 2003 | 05:44 PM
Nate B's Avatar
Default Compression test results
I used a craftsmen compression tester and came up with the following. Seems ok for an engine with 38850 miles and in need of a valve adjustment.
#1 - 215
#2 - 230
#3 - 235
#4 - 230
Any reason why number one would be the lower of the cylinders or do these numbers seem alright? Also, when I checked the #2 I cranked about 5-6 times at WOT and first only came up with 197, then after checking the remainding cylinders I went back to #2, cranked 5 times again and came up with a final result of 230. Everything seem ok?
Old Jun 17, 2003 | 05:45 PM
BlueR's Avatar
Default Re: Compression test results (Nate B)
why don't you try number one again?
Old Jun 17, 2003 | 05:48 PM
Nate B's Avatar
Default Re: Compression test results (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">why don't you try number one again?</TD></TR></TABLE>good point, although I figured it seemed to be in spec. I'll try again though to see what happens.
Old Jun 17, 2003 | 05:49 PM
cheezthis's Avatar
That's looks pretty normal for all the ITR's I've done a test on...right around the 230 mark.
Old Jun 17, 2003 | 06:10 PM
Chubz's Avatar
Default Re: Compression test results (cheezthis)
a valve adjustment could clean up cyl 1 to even the compression with the rest
Old Jun 17, 2003 | 07:26 PM
Daly's Avatar
New User
Default Re: Compression test results (B18CR01)
Do dealerships routinely do compression tests as a part of scheduled maintainence??
Old Jun 17, 2003 | 07:58 PM
Chubz's Avatar
Default Re: Compression test results (Daly)
not that i know of, only if you specify
Old Jun 17, 2003 | 09:04 PM
Chris N's Avatar
Mine were about the same, except #1 was a bit higher. I wouldn't be concerned, you do need a valve adjustment.... then do compression again.
Old Jun 17, 2003 | 09:36 PM
seanb18c1's Avatar
With 85000 miles GSR: w/mild cams
230-225-230-230
Old Jun 17, 2003 | 09:39 PM
cheezthis's Avatar
Default Re: (seanb18c1)
Hehe...for good measure...
100k miles GSR w/stock cams
220-225 across the board
Old Jun 17, 2003 | 09:45 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: (cheezthis)
Did you guys crank it 7 times with the throttle plate opened? You're supposed to nail it seven times and it should go up at a even and steady pace. I cranked it 4 times without the throttle opened and i hit 250's and 260's all the way up.
Old Jun 17, 2003 | 09:52 PM
seanb18c1's Avatar
you crank the car until compression no longer builds up, doesn't matter how many times. However, the fewer, the better.
Old Jun 17, 2003 | 09:56 PM
cheezthis's Avatar
Mine wasn't at WOT...I forgot do that when I did mine, but then again, I don't care right now because my numbers looked good.
And yes, you crank until it stops.
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
dbiker207
Nov 26, 2006 07:10 AM
Chubz
Honda S2000
20
May 1, 2006 10:37 AM
xd69
Mar 7, 2006 12:10 PM
snowblind7x
Apr 13, 2005 08:12 PM
