wierd vibration at 45 to 65mph not wheels out of balance
when i accellerate i can feel this wierd shimmy like something is out of balance. I know that its not my wheels and does it in every gear if i accelerate only around 45 to 65 mph.. think it might be cv axles but not clicking noises coming from them. Well gimme your input and i'll try to swap out cv axles to see if thats the problem .. I'll keep you all posted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seekerONE »</TD></TR><TR><TD CLASS="quote">vibration that occurs only on acceleration is usually inner cv joints.
when the inner joints go bad they don't make any noises (like the outer joints click)</TD></TR></TABLE>
he is right..
for a correct diagnosis
he is right..
Dude..I know you dont think its your wheels needing a balance...but they do...take them to a shop and get them re balanced rotated and put on...the shimmy should go away. (I say this cause it happened to me!)
wheels are new and balanced, alignment is dead on, changed passenger side axle and still vibrating on acceleration. Im about to do the drivers side to see if it helps , i'll keep ya posted...
replaced drivers side cv axle and intermediate shaft and still vibrating....new plugs wires and modified cap and rotor button and still shimmying like crazy.. only thing i can think of is either tranny is goingout (hope not) or clutch is chattering... PLEASE HELP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef ***** »</TD></TR><TR><TD CLASS="quote">rack?</TD></TR></TABLE>
That would be my guess too...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxzcgasd »</TD></TR><TR><TD CLASS="quote">think my drivers side tie rod end is bad gonna check it out today..</TD></TR></TABLE>
Good Luck man. I'd help but as you know my tranny is busted.
thanx geoff
i replaced all tie rods and got an alignment and still doing it.
i know the problem now but dont want to fix it. Its clutch chatter i must have burnt a spot on my flywheel or pressure plate so im ordering a new clutch and will keep ya posted
