just got my HID's BUT.....
Old Jun 15, 2003 | 05:02 AM
SHystrdyGSRtdy's Avatar
Default just got my HID's BUT.....
i just got my hella hid 5200k for my 99 gsr and i love them. but the left side is a little yellowish/greenish. also....when i turn it on, the left side flickers like a candle not a lot...just looks like the bulb is wobbling up and down... anyone know why this would happen? also....i'm running 30 fuse for the L & R low beam....my friend told me to because he tried 15 and it blew on him....
thanks...
Old Jun 15, 2003 | 05:06 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: just got my HID's BUT..... (iLUVmySH)
i got the same problem with my h1s. MTKcommander (hid ****) told me that it's because of the chemical in the bulb. you can try to fix it by taking out the bulb and hang it upside down so the chemical can mix properly.
Old Jun 15, 2003 | 05:07 AM
Default Re: just got my HID's BUT..... (StickyTire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StickyTire &raquo;</TD></TR><TR><TD CLASS="quote">i got the same problem with my h1s. MTKcommander (hid ****) told me that it's because of the chemical in the bulb. you can try to fix it by taking out the bulb and hang it upside down so the chemical can mix properly. </TD></TR></TABLE>
did it work for you? hang for how long? just once or do it periodically?
Old Jun 15, 2003 | 06:53 AM
ebelp's Avatar
Are you sure the bulb isn't loosely seated in the headlight housing?
Old Jun 15, 2003 | 10:53 AM
Default Re: just got my HID's BUT..... (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure the bulb isn't loosely seated in the headlight housing?</TD></TR></TABLE>
positive...i've tried screwing it tighter but it won't go.... and someone said not to do it too hard for it might break...
Old Jun 15, 2003 | 03:43 PM
* B A N N E D *
nope it didn't work. it's slightly yellowish/greenish. i should've done it before the install. it has something to do with bulb aging, i hope it changes color in the future. it only looks like that from a close distance. from far away, i can't really tell. time for new bulbs?
btw, what brand hid do you have? and from who?
Old Jun 15, 2003 | 04:39 PM
:jdmshmaydm:'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StickyTire &raquo;</TD></TR><TR><TD CLASS="quote">nope it didn't work. it's slightly yellowish/greenish. i should've done it before the install. it has something to do with bulb aging, i hope it changes color in the future. it only looks like that from a close distance. from far away, i can't really tell. time for new bulbs?
btw, what brand hid do you have? and from who?</TD></TR></TABLE>
It could be the housing, not the bulbs. You ever considered that?
Old Jun 15, 2003 | 08:26 PM
Default Re: just got my HID's BUT..... (Gatecrasher19AF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gatecrasher19AF &raquo;</TD></TR><TR><TD CLASS="quote">
It could be the housing, not the bulbs. You ever considered that? </TD></TR></TABLE>
5200k is more bluish on other integs with the same projectors compared to mine.. i'll check my housing to see if there's crap in it to clean out....but i still need an explaination about the flickering thing
Old Jun 15, 2003 | 08:42 PM
MachAF's Avatar
Mine flicker too. Well one doesn't anymore since I got a newer generation ballast.
Flickering on warm up is normal though.
Default Re: just got my HID's BUT..... (MachAF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">Mine flicker too. Well one doesn't anymore since I got a newer generation ballast.
Flickering on warm up is normal though.</TD></TR></TABLE>
only one side flickers..doesn't look good
robbys89
Feb 9, 2009 09:44 AM
Infamous_Imports
Sep 6, 2006 09:48 PM
Devine
Nov 28, 2005 02:31 PM
shift6th
Honda S2000
Apr 13, 2004 03:49 AM
MugenHonda
Nov 13, 2003 10:49 PM
