how to fill my pin holes on bondo! an can i get a mix somthing with my primer to get a hevy coat of
Old Jun 14, 2003 | 10:46 AM
gulf imports
Guest
Posts: n/a
Default how to fill my pin holes on bondo! an can i get a mix somthing with my primer to get a hevy coat of
how to fill my pin holes on bondo! an can i get a mix somthing with my primer to get a hevy coat of it???
Old Jun 14, 2003 | 10:52 AM
This One's Avatar
Default Re: how to fill my pin holes on bondo! an can i get a mix somthing with my primer to get a hevy coat
use high build primer....
if you still have pin holes, use some glazing putty
Old Jun 14, 2003 | 11:05 AM
Ronin Panda's Avatar
just make your primer 50/50 spray it on heavy but not heavy enough to run it sand it dry with 600 grit paper prime it again not so heavy but still enough to cover then sand once again with 600 ..wala no pin holes
Old Jun 14, 2003 | 11:10 AM
gulf imports
Guest
Posts: n/a
so your sayin do two coats?
Old Jun 14, 2003 | 11:30 AM
This One's Avatar
Default Re: (gulf imports)
coats depends on what your spraying.. what kind of primer do you have... you'll need more than 2 coats to fill pin holes
Old Jun 14, 2003 | 11:44 AM
gulf imports
Guest
Posts: n/a
Default Re: (tHE oNE)
Rayflex Synthetic Enamel grey primer an i have to mix either synthetic or acrylic reducer?? which one is better?
Old Jun 14, 2003 | 03:44 PM
gulf imports
Guest
Posts: n/a
Old Jun 15, 2003 | 01:25 PM
gulf imports
Guest
Posts: n/a
y
Old Jun 15, 2003 | 02:56 PM
This One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gulf imports &raquo;</TD></TR><TR><TD CLASS="quote">Rayflex Synthetic Enamel grey primer an i have to mix either synthetic or acrylic reducer?? which one is better?</TD></TR></TABLE>
acrylic is lacquer, and so is enamel i think....
use whatever reducer it says on the can of primer
I have no idea what that **** you just said is... either way...
you dont wanna use lacquer primer, its junk and wont protect from the elements..
what are you trying to do...?
dont listen to whoever said 50/50... you need to look at the can, depending on what this **** you used is... you may hardener and some primers are 3:1 or 3:1:1, if it doesn't need hardener, its probaly junk and it is only going to be mixed 1:1
you may need to do some other things...
your best bet would be to get a 2k primer and then use sealer, then spray it...
Old Jun 15, 2003 | 06:17 PM
tnbigdawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tHE oNE &raquo;</TD></TR><TR><TD CLASS="quote">
your best bet would be to get a 2k primer and then use sealer, then spray it...</TD></TR></TABLE>
get a 2k primer, its urethane. block sand it with 150grit dry up to 220. then primer again and wetsand with 400(if your gonna spray sealer) or sand with 600grit(if you are not using sealer).
I recommend using sealer because it provides adhesion and fills in the sandscratches.
Dupont/Nason ppg/omni all make good primers.
to fill in pin holes, use a catylized glazing putty(AKA icing)
good luck
Old Jun 15, 2003 | 07:54 PM
96integra20's Avatar
DURAMIX.....works great.......even on metal.
Old Jun 16, 2003 | 12:54 PM
gulf imports
Guest
Posts: n/a
bondo work better~!
ek4shizzle
Paint and Body
Dec 7, 2007 01:06 PM
95ejjj
Jan 30, 2006 05:01 PM
silentdaredevil2
Welding / Fabrication
Dec 27, 2005 03:04 PM
kniob
Jul 13, 2005 11:22 AM
ITRFetish2000
May 27, 2004 08:26 AM
