Stand Alone users, at what RPM are you guy's enableing and disableing VTEC?
Old Jun 7, 2003 | 09:52 PM
turbo Si's Avatar
Default Stand Alone users, at what RPM are you guy's enableing and disableing VTEC?
My tuner has mine set to enable at 5200 rpm, and disable at 5000 rpm. Where do you guy's stand on this?
Old Jun 7, 2003 | 10:00 PM
95c1v1cs1's Avatar
Default Re: Stand Alone users, at what RPM are you guy's enableing and disableing VTEC? (turbo Si)
Mine goes in at 5200. I am not sure when it kicks out.
Old Jun 7, 2003 | 10:11 PM
Arturbo's Avatar
Better than steak
25 Year Member
https://honda-tech.com/zerothread?id=521785
Old Jun 7, 2003 | 11:58 PM
AlLMoToRvOtEr's Avatar
Default Re: Stand Alone users, at what RPM are you guy's enableing and disableing VTEC? (Arturbo)
From what I have heard the best spot for vtec to come in at is 5500 RPM but that could all change do to your setup. Best advice would to get the car on the dyno and play with it alittle not like it's a hard thing to change.
Old Jun 8, 2003 | 01:09 AM
TurboDANDEE's Avatar
i think it all depends on the cams.
Old Jun 8, 2003 | 01:11 AM
AbaZ's Avatar
Wherever the dyno graph dips, you just keep adding it up higher and higher, until its a nice smooth line.
that is a good example of why vtec needs to be turned up, it may sound cooler at a lower rpm, but you have a better transition from vtec to boost when its higher. I personally have mine set at 5800
(no thats not my graph either, lol)
Jeff
Old Jun 8, 2003 | 01:17 AM
Default Re: Stand Alone users, at what RPM are you guy's enableing and disableing VTEC? (AbaZ)
good point man
Old Jun 8, 2003 | 01:45 AM
Arturbo's Avatar
Better than steak
25 Year Member
If you look at a datalog of a what happens when vtec engages you will see that timing is pulled back on a stock computer. Honda does this to avoid detonation with the sudden intake. The dip you see is caused by the cams but more to the timing being pulled back. If you have stand alone you shouldnt have that dip in there.
art
Old Jun 8, 2003 | 03:02 AM
SiR Kid's Avatar
New User
6000 rpm on my ITR cams, which are being pulled dout for GSR's because of the overlap. I don't have cam gears to simplify a little, so don't go off on how ITR are better, GSR's are weak, blah blah blah. We tried to tune out the dip at VTEC on my Z-Dyne, but no amount of timing, fuel etc, made it work any better, so this was the compromise we had to come to.
Anyway, I still had a dip from overlap , even when engaging at 6000!
[edit]I know, I know, weak, and VERY sloppy dyno chart. The smoothing factors were turned off, and my plug gap was blowing out the spark above 7500. SORRY! [/edit]
Old Jun 8, 2003 | 05:02 AM
turbo Si's Avatar
Default Re: Stand Alone users, at what RPM are you guy's enableing and disableing VTEC? (SiR Kid)
I guess I missed that thread earlier in the week.
We'll I guess I should leave it at 5200 rpm. On all my dyno graphs, I have no dip what so ever. At 5200 rpm it just keeps climbing!
ArniFPR
Jan 8, 2016 04:15 PM
TurboEG6262
Mar 8, 2013 12:39 PM
khronicboy420
Dec 28, 2008 09:01 AM
EJ1chevelle
18
Aug 23, 2007 01:25 PM
Death_to_Thieves
Oct 31, 2002 06:21 PM
