What does a FULL pre-turbo tune-up consist of?
Old Jun 5, 2003 | 10:36 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default What does a FULL pre-turbo tune-up consist of?
besides oil change and spark plugs?
Old Jun 5, 2003 | 10:38 AM
b18bturbo's Avatar
Default Re: What does a FULL pre-turbo tune-up consist of? (fnananon)
oil change spark plugs new rotor, cap plug wires would be all nice. i would drain change your fluid check your timing belt replace if you want ot. also check the water pump see if you want to replace that as well. not really necessary though.
main things would be oil water and distributor stuff
Old Jun 5, 2003 | 11:09 AM
quikB18B's Avatar
Default Re: What does a FULL pre-turbo tune-up consist of? (b18bturbo)
Do a compression test also,
Old Jun 5, 2003 | 12:05 PM
arsenaldragster's Avatar
Default Re: What does a FULL pre-turbo tune-up consist of? (quikb20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikb20 &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression test also,</TD></TR></TABLE> wouldnt hurt..
Old Jun 5, 2003 | 12:31 PM
Mase's Avatar
Default Re: What does a FULL pre-turbo tune-up consist of? (arsenaldragster)
all good suggestions.
Old Jun 5, 2003 | 12:41 PM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">oil change spark plugs new rotor, cap plug wires would be all nice. i would drain change your fluid check your timing belt replace if you want ot. also check the water pump see if you want to replace that as well. not really necessary though.
main things would be oil water and distributor stuff</TD></TR></TABLE>
when would you recommend changing the cap and rotor?? ive done all of whats listed except for a new cap and rotor... my motor has about 92k on it right now and runs fine
Old Jul 1, 2003 | 12:38 PM
Default Re: What does a FULL pre-turbo tune-up consist of? (Civtek)
anyone else?
civlxbro
Jan 8, 2009 02:42 PM
VTECth1s
Jun 19, 2007 04:00 PM
nightrise420
Mar 5, 2007 04:10 PM
Bbasso
Nov 3, 2003 04:27 PM
imported204
Apr 27, 2002 11:23 AM
