tune up
Old Apr 26, 2002 | 08:52 PM
imported204's Avatar
Default tune up
My car has 92k miles and i think its time for a tune up. What sort of things should i check/ change. I just recently had the timing belt, and water pump changed. How hard is it to get the spark plugs? Do i need the platinum ones, or is that only necessary in VTEC`s? its a 93 si.
Old Apr 26, 2002 | 09:21 PM
PrecisionH23a's Avatar
Default Re: tune up (imported204)
At 90k the biggest thing is timing belt and water pump. You can replace some of your other belts, such as power steering and altenator belts. Change tranny fluid, oil, check other fluids, replace spark plugs (NGK plat's are nice), new plug wires (magnecore 8.5's rock), and adjust your valves. Spark plugs are simple to install. you just need a 6" extension to reach the spark plugs to install/remove them.
[Modified by GudeH23a, 1:22 AM 4/27/2002]
Old Apr 27, 2002 | 11:23 AM
Chiovnidca's Avatar
Default Re: tune up (GudeH23a)
Rotor buton, air filter and serviceing your brakes should also be included at 90,000.
supergtp1
Jun 2, 2014 10:22 PM
aandrewcc
Mar 26, 2006 08:30 AM
mtfugi8
May 31, 2005 12:51 PM
boostincoupe
Jul 1, 2003 12:38 PM
tr4il
Jan 4, 2002 06:41 PM
