HELP! just put in turbo and drove for a block and smoke came out..
Old Jun 2, 2003 | 12:42 PM
igo4bmx's Avatar
Default HELP! just put in turbo and drove for a block and smoke came out..
well i could faintly smell the smoke, but when i popped the hood, i could see faint smoke coming from the turbo!!! any help???!
Old Jun 2, 2003 | 12:46 PM
Mr. Softee's Avatar
Default Re: HELP! just put in turbo and drove for a block and smoke came out.. (igo4bmx)
is it new
TeStUdO's Avatar
so smoke was coming from the turbo?? cheack the charge pipes for oil. you might have a bad seal
Old Jun 2, 2003 | 12:48 PM
igo4bmx's Avatar
it was a used greddy kit..
i just saw the manifold and saw smoke coming not from it, but below...
and what is a bad seal?
Old Jun 2, 2003 | 12:50 PM
Ri5e's Avatar
Default Re: (igo4bmx)
Well if the turbo has been sitting for a while, it will smoke for a bit. Maybe for like an hour. I've had it happened. A friend had a turbo sitting in his room for a couple months and finally decided to use it and it was smoking a lot. After 30 mins it was still smoking. The next day there was no smoke.
If it continues to smoke, it could be:
1. Pinched oil return line, causing the oil to "flood" the turbo seals
2. Bad seals
Old Jun 2, 2003 | 12:55 PM
TeStUdO's Avatar
if its a bad seal and the turbo is leaking oil then you will have to get it rebuilt. http://www.cheapturbo.com <---- here is a place that does rebuilds
Old Jun 2, 2003 | 01:04 PM
DeepSi's Avatar
Default Re: (TeStUdO)
You also might have an exhaust leak. I had very faint smoke coming out for the first few minutes and it was coming from the downpipe was not on tight enough a small gap.
Old Jun 2, 2003 | 01:10 PM
mamaboy's Avatar
don't think of the worst thing....first try something simple like retorquing everything....manifold...turbo to manifold...downpipe.....oil feed/drain....
Old Jun 2, 2003 | 01:38 PM
igo4bmx's Avatar
Default Re: (BG Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BG Boost &raquo;</TD></TR><TR><TD CLASS="quote">Well if the turbo has been sitting for a while, it will smoke for a bit. Maybe for like an hour. I've had it happened. A friend had a turbo sitting in his room for a couple months and finally decided to use it and it was smoking a lot. After 30 mins it was still smoking. The next day there was no smoke.
2. Bad seals</TD></TR></TABLE>
damn it... pinched oil return line... and i can't unpinch it...
i'm gonna try to wrap a clamp around the line to force it to open
Old Jun 2, 2003 | 01:59 PM
spoolinlude's Avatar
I live under a rock
or u could just by a new one??
Old Jun 2, 2003 | 06:10 PM
igo4bmx's Avatar
ok, i fixed the line, but i still smell something... no smoke though... should i worry?`
Old Jun 2, 2003 | 06:53 PM
TeStUdO's Avatar
what kind of smell is it? like oil burning? is the smell at idle or after you drive it?
Old Jun 2, 2003 | 06:54 PM
igo4bmx's Avatar
well after i drive it, and let it idle for a bit before turning it off ( i have a turbo timer, but not powered up) anyways i jump out and i can smell through the front grill this odor.. i can't describe... maybe its burning oil?
Sim
Feb 13, 2008 10:19 PM
johnny_dc2
Apr 4, 2006 06:47 PM
BlackDAy
Sep 16, 2005 07:57 AM
T--Rex
May 29, 2005 11:24 AM
