ok i fawked up! Bought a gude head for turbo setup ERRRR!help
Old May 29, 2003 | 07:01 PM
ludesleep's Avatar
Default ok i fawked up! Bought a gude head for turbo setup ERRRR!help
Ok Gude didnt tell me that their heads were milled so much which i should have researched from the start. Anyways i have golden eagle block with je 9:1 pistons, should i buy a thicker head gasket for go for it. How hard do you guys think it will be to tune..
Where can you buy thicker head gaskets that work on oringed blocks..i need ideas guys help me out
Old May 29, 2003 | 07:18 PM
red cx's Avatar
Default Re: ok i fawked up! Bought a gude head for turbo setup ERRRR!help (ludesleep)
I built a ls/vtec for my friend and he got the gude head package. The head is milled like a mother F*cker. You do have lower comp. pistons. If i were in your shoes i would get a thicker head gasket. But that also depends on your fuel managment and how much boost you want to push. If you want to boost in a low psi range, like under 6 i would try to see if i could be tuned safe.
Old May 29, 2003 | 07:19 PM
TurboTeG4's Avatar
I bought a turbo head and it was only milled just slightly so where u can apply the head gasket???????
Old May 29, 2003 | 07:21 PM
ludesleep's Avatar
Default Re: ok i fawked up! Bought a gude head for turbo setup ERRRR!help (turbocivic4)
im going big boost 23psi on a t360-1
Old May 29, 2003 | 07:43 PM
Shift!'s Avatar
kinda hard to tell unless you can figure out your Comp Ratio N/A. If its going to be high (above 10) running that kind of boost might cause problems for you.
Old May 29, 2003 | 08:11 PM
Cole D's Avatar
Default Re: ok i fawked up! Bought a gude head for turbo setup ERRRR!help (Shift!)
Hey the gude head is going to put your compression ratio at (estimated of course) 10.2-10.6 with a stock head gasket so you decide from there.
Chris
Old May 29, 2003 | 08:16 PM
ludesleep's Avatar
Default Re: ok i fawked up! Bought a gude head for turbo setup ERRRR!help (chriscoleman102)
so will a thicker head gasket fix this problem where can i buy em at?
Old May 29, 2003 | 09:14 PM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep &raquo;</TD></TR><TR><TD CLASS="quote">im going big boost 23psi on a t360-1</TD></TR></TABLE>
Exactly 23psi, eh? If you're going to do that, I would pay a little more attention to detail...otherwise you may not have a single motor for very long...just lots of little pieces.
You could just run LESS boost with higher compression and make about the same power with faster spool-up. .02
Old May 29, 2003 | 09:36 PM
ludesleep's Avatar
Default Re: ok i fawked up! Bought a gude head for turbo setup ERRRR!help (ion_four)
thats true
Old May 30, 2003 | 02:54 AM
trickeng's Avatar
COMETIC(1 440 354 0777) is the place for any style headgasket. i typically run there .057 HP on stock motors.
integraturbo
Oct 29, 2008 10:56 AM
2civichatchbs
Feb 12, 2004 06:31 AM
Nikolai
Nov 14, 2002 12:34 PM
ludelvr
May 26, 2002 11:57 PM
InfamousRS
May 1, 2002 02:15 PM
