LS swap in 93 delsol?
Old May 26, 2003 | 07:17 PM
11secdx's Avatar
Default LS swap in 93 delsol?
i did this swap and i am looking on information on whether i need to repin anything. i used the delsol engine harness, pr4 ecu,plugged everything in. but i have no spark and the fuel pump does not cut on. it spins over but no starting.please help
Old May 27, 2003 | 05:50 AM
VTECVillain's Avatar
Default Re: LS swap in 93 delsol? (11secdx)
Check all of your connections and grounds.
Old May 27, 2003 | 07:54 PM
11secdx's Avatar
Default Re: LS swap in 93 delsol? (VTECVillain)
i've checked everthing three times. i don't understand. i rebuilt the distributer and still no spark. to get the fuel pump to cut on i have to straight wire it. is there anything i could be missing.
Old May 29, 2003 | 03:34 PM
11secdx's Avatar
help
Old May 29, 2003 | 03:49 PM
poison's Avatar
Does your CEL turn off after 2 seconds with the key in the ON position?
Also, listen for your fuel pump turning on.
Keep us posted.
Old May 29, 2003 | 04:52 PM
11secdx's Avatar
Default Re: LS swap in 93 delsol? (poison)
when i turn the key to the ON position, the CEL comes on and stays on. the fuel pump does not come on. i wired it the battery, just to check and the pump works, just not with the switch.
Old May 29, 2003 | 05:25 PM
poison's Avatar
Ok. The main relay or the ECU is either faulty, not plugged in, or you have a blown fuse.
Check the ECU fuse and back up fuse. It's located on the underhood fuse panel on the upper left hand corner looking straight at it. The ECU back up fuse is just to the right of that. Both I believe are 15A.
ALSO.
Check the ACG fuse, which is located right next to the SRS fuse which is also a 15A fuse located on the under DASH fuse panel.
If all fuses are good, then make sure the main relay and the ECU are all plugged in, and ALL grounds are securely bolted/tightened down.
If all else goes, then take out the main relay, and try and swap a buddy with the same OBD car to see if it's the main relay. Also switch ECU's as well.
That hopefully will track down the problem.
The main relay/ecu not turning on WILL cause the Ingnitor to not turn on, as well as the fuel pump. This is the exact reason you are not getting spark/fuel.
HTH and keep us posted.
Old May 29, 2003 | 05:28 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Ok. The main relay or the ECU is either faulty, not plugged in, or you have a blown fuse.
ALSO.
HTH and keep us posted.</TD></TR></TABLE>
good one
Old May 29, 2003 | 05:31 PM
poison's Avatar
Default Re: LS swap in 93 delsol? (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">
good one </TD></TR></TABLE>
thanks man
Old May 29, 2003 | 05:35 PM
poison's Avatar
Just to add on and be more specific. The grounds include:
Engine ground which is on the transmission.
Engine harness ground on the thermostat housing.
Main relay/dash harness ground which is located near the driver side dash bracket (to mount the dash).
Battery ground (you know where this is).
Valve cover ground (on the valve cover).
Dash/cluster ground which is located just behind the gauge cluster and goes onto a little butt connector mounted on the steering column support.
I believe that's all or the majority of the grounds. Someone please fill me in if I have missed any.
Old May 29, 2003 | 07:05 PM
11secdx's Avatar
poison- i really do appreciate the input. i will be trying this as soon as the sun comes up. thanks again, and i will touch base as soon as i have checked all these.
1.6si
Jan 18, 2018 11:59 AM
electron_si
Feb 18, 2008 08:17 AM
frost_0ne
Sep 13, 2005 01:02 PM
DenMatic
21
Feb 3, 2004 05:51 PM
