FUEL PUMP NOT PRIMING????????????
Old 09-09-2005, 01:49 PM
frost_0ne's Avatar
Default FUEL PUMP NOT PRIMING????????????
searched threads found nothing.
heres my problem. when i turn the key to the on position the fuel pump doesnt prime i checked the main relay to see if that was the problem and the relay is fine i even checked to see if the positive wire going to the fuel pump was getting power and im getting nothing i also replaced the fuel pump thinkin it was that at first is there any other things i can check farther back before the relay ohh even switched my ecu to see if that might help as well
thanx in advance
Old 09-09-2005, 02:18 PM
NJcoupe's Avatar
same thing happened to me, check the ecu grounds which is on the t-stat housing. Also, wiggle on the engine harness, while trying to start it. I did everything you did, wiggled the engine harness, and it started, reason was, was because the harness wasn't in the correct/oem location, and it was pulling on one of the pins.
Old 09-09-2005, 02:19 PM
93civicEX's Avatar
Isn't there a fuse for the fuel pump?
Old 09-09-2005, 04:17 PM
NJcoupe's Avatar
There's Multiple fuses for it. fuse 8, fuse 24. theres many fuses that relate to anything with the main relay, and fuse pump/ecu fuses.
Old 09-09-2005, 05:21 PM
Whig-it's Avatar
I would check the ground @ the T-Stat housing, that was my problem
Old 09-09-2005, 05:29 PM
Do_Ster's Avatar
check the ACG fuse under the dash. forgot what what amp it is, i believe a 15, but that fuse gives symptons of a bad fuel pump and/or main relay
Old 09-09-2005, 06:56 PM
frost_0ne's Avatar
Default Re: (Do_Ster)
alright thanx im gonna go check on these things
Old 09-10-2005, 12:59 PM
NJcoupe's Avatar
any word?
Old 09-13-2005, 01:02 PM
frost_0ne's Avatar
Default Re: (RHDej2.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHDej2. &raquo;</TD></TR><TR><TD CLASS="quote">any word?</TD></TR></TABLE>
thanx RHDEJ2 turns out it was fuse 24 i didnt even know there was a fuse for the fuel pump since its not listed thanx for the help
dgdarien
07-20-2017 02:37 AM
SPUNKYMUNKY
11
03-27-2015 03:58 PM
civic91sief
11-05-2009 10:59 PM
snzh22
08-08-2007 04:53 PM
gsrt nick
10-23-2006 06:43 PM
Quick Reply: FUEL PUMP NOT PRIMING????????????
