A few fuel management questions
Old May 23, 2003 | 02:20 PM
EG(6)SR's Avatar
Default A few fuel management questions
okay, sorry if these questions have been covered before, but I can't find anything about my specific situation in the archives. Help is very much appreciated.
I have a b18c1 in a 92 civic cx hatchback. I have pieced together a turbokit. Now i'm wondering about the fuel management. I'm using a turbonetics deltagate, silver spring (7-9psi), I'm turning it down to 7psi, would you recommend for me just to buy the 5-7 spring to be on the safe side?
Please tell me the advantages and disadvantages of following sceinarios:
1.) Integra intank fuel pump, with inline fuel pump (msd), and 12:1 fmu
2.) walbro 255 intank fuel pump, 12:1 vortech fmu
3.) Single Cam (stock) fuel pump, 12:1 vortech fmu
I'm aware that running larger injectors and hondata will provide a much smoother setup, so please don't tell me to do that. As of right now, I don't have the funds for that. With the above settings, please choose the best one, as well as a relatively safe psi to boost at. Thanks.
Old May 24, 2003 | 12:52 PM
EG(6)SR's Avatar
Default Re: A few fuel management questions (EG(6)SR)
bumper!
Old May 24, 2003 | 06:16 PM
EG(6)SR's Avatar
bump~!
por favor!
Old May 24, 2003 | 10:04 PM
EG(6)SR's Avatar
Okay...61 views with no posts.....urr okay.
Old May 24, 2003 | 10:09 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG(6)SR &raquo;</TD></TR><TR><TD CLASS="quote">Please tell me the advantages and disadvantages of following sceinarios:
All three of those scenarios are a problem----no missing link! you'll get a CEL 03 no matter what.
Old May 24, 2003 | 10:16 PM
zip's Avatar
zip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG(6)SR &raquo;</TD></TR><TR><TD CLASS="quote"> Now i'm wondering about the fuel management.
As of right now, I don't have the funds for that. With the above settings, please choose the best one, as well as a relatively safe psi to boost at. Thanks.</TD></TR></TABLE>
Another alternative is the SMC and 440-550cc injectors. You can run the stock fuel system with this setup easily up to 11-14psi.
Click here for more info: SMC
Old May 24, 2003 | 10:29 PM
EG(6)SR's Avatar
Default Re: A few fuel management questions (Daniel)
I'll have the missing link. thanks for the replies guys.
Zip, I'm sorry, i'm pretty new to forced induction (excuse, i know) but I'm not to familiar with SMC, the site given, was pretty informative, but is it a piggy back system like hondata? Is it adjustable, is it a chip, or is it some device to control? I'm in the bay area, so i'm definatey willing to check it out. Everyone else, need your opinions too!
Old May 24, 2003 | 10:38 PM
zip's Avatar
zip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG(6)SR &raquo;</TD></TR><TR><TD CLASS="quote"> is it a piggy back system like hondata? Is it adjustable, is it a chip, or is it some device to control? I'm in the bay area, so i'm definatey willing to check it out. Everyone else, need your opinions too!</TD></TR></TABLE>
The SMC works with your exisiting ECU and allows the user full control over fuel delivery at various rpms. Basically, all you need with the SMC is larger injectors to make it work with a FI Honda; no FMU, fpr, or larger fuel pump needed! Click here for more info:
SMC models
Old May 24, 2003 | 10:55 PM
Sonny's Avatar
Default Re: A few fuel management questions (zip)
SMC
Sonny
Old May 25, 2003 | 08:36 AM
Hondata's Avatar
Piggyback systems always use a microprocessor to take over some of the stock ECU's inputs (such as sensors) and outputs (such as injectors)
The Hondata system is not piggyback. It is a reprogrammable stock Honda ECU. No wires are cut to install it.
Old May 25, 2003 | 05:01 PM
Joseph Davis's Avatar
Default Re: A few fuel management questions (Hondata)
Hondata = Honda-only standalone.
zip, I tried your links earlier and they didn't work. How do you get 11-14 psi on the SMC, using a GM 2 bar? I rode in a CRX running one the other day, it was much like an AFC hack'd vehicle (of course) for a much better price.
Old Jun 25, 2003 | 07:54 PM
DOHCtorTHRUST's Avatar
Default Re: A few fuel management questions (J. Davis)
zip, it looks like a wonderful system... cost effective.... but how do you read your adjustments or how do you know if its the right setting(other then dyno tunning), is there a monitor reading device somewhere? is it like the VAFC's?
RJ, still no dice with the DOHC fuel pump huh...
Turbocivic94
Jun 1, 2004 03:04 PM
threatcon13
Oct 28, 2003 09:13 PM
civicdragger818
Jun 20, 2003 01:07 PM
gsr sol
Aug 29, 2002 09:18 AM
