wtf are these?
Old May 22, 2003 | 11:08 AM
JDMCivicHatch93's Avatar
Default wtf are these?
i put my digicam under my intakemani. and got this picture to try and locate my knock sensor. is it the one on top? and if so then what is the green one on bottom? if not then what are both?? btw my ecu is throughing a code 23. and i have you are looking at the back side of a first gen jdm b16. and my check engine light only comes on after the car warms up completely.
Old May 22, 2003 | 11:20 AM
AllmotorJunkie's Avatar
Default Re: wtf are these? (JDMCivicHatch93)
I think the knock sensor is the green one...not 100% sure.
Old May 22, 2003 | 11:28 AM
Nextelbuddy's Avatar
Default Re: wtf are these? (AllmotorJunkie)
knock sensor is the top one the green one is the oil temp. sensor
Old May 22, 2003 | 12:16 PM
Default Re: wtf are these? (nextelbuddy)
ok sorry but i got one more question then....
a. what do these plug into they dont look like they would fit either the oil temp sens. or the KS..
b. and these
c. and what is the thing in the circle
Old May 22, 2003 | 12:38 PM
TurBoXBirD16's Avatar
i can only answer one question
the circled thing is the OIL pressure sensor
good luck
Old May 22, 2003 | 12:57 PM
johnzm's Avatar
u shoulda labeled everyhting. then u wont have these problems. that 3 wire one looks like a TPS, or a MAP.
Old May 22, 2003 | 12:59 PM
paul93sir's Avatar
none of the 2 grey plugs are the iol they are either map or tps if u dont have them connected
Old May 22, 2003 | 01:05 PM
KS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCivicHatch93 &raquo;</TD></TR><TR><TD CLASS="quote">i put my digicam under my intakemani. and got this picture to try and locate my knock sensor. is it the one on top? and if so then what is the green one on bottom? if not then what are both?? btw my ecu is throughing a code 23. and i have you are looking at the back side of a first gen jdm b16. and my check engine light only comes on after the car warms up completely.
OK.. the top sensor is suppose to be the knock snesor, but it's broken. The one on the bottom with the two prongs is the fan switch. Only pre 91 engines have those.
THose grey plugs you were showing later on were TPS and MAP plugs.
Old May 22, 2003 | 01:17 PM
Default Re: wtf are these? (KS-R)
ok thanks. so if i got a new knock sensor which plug do i hook it up to.
anyone know what knock sensor i should get like model and year
or does someone have one i could buy??
Old May 22, 2003 | 01:22 PM
poison's Avatar
knock sensors are universal. just ask to purchase one or talk with Honda
Old May 22, 2003 | 10:34 PM
Default Re: wtf are these? (poison)
what does not having a KS do to my car. is it ok to drive with out it or is it running in a fail safemode or somthing making it run bad?
Old May 22, 2003 | 11:29 PM
K20  EG's Avatar
ummm the one looks to be a smegma valve ...the other could be might be a flux capacitor
It makes time travel possible dude
Old May 22, 2003 | 11:59 PM
salbaje's Avatar
the green plug is vtec solenoid and the other is prob oil pressure.
the circled sensors are fan switch and knock like the other post said
Old May 23, 2003 | 08:10 AM
Default Re: wtf are these? (B20---Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20---Vtec &raquo;</TD></TR><TR><TD CLASS="quote">ummm the one looks to be a smegma valve ...the other could be might be a flux capacitor
It makes time travel possible dude</TD></TR></TABLE>
i would agree but its not a DELOREAN... smart @$$
Old May 23, 2003 | 09:43 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCivicHatch93 &raquo;</TD></TR><TR><TD CLASS="quote">ummm the one looks to be a smegma valve ...the other could be might be a flux capacitor
You can have the knock sensor funtion disabled within the ECU. Not really recomended, but a lot of chipped ECU's have the knocks sesors disabled. Has the car been started? Are you throwing any codes?
Old May 24, 2003 | 08:52 PM
Cory man's Avatar
Default Re: wtf are these? (Mr Milano)
Correct me if Im wrong but you are doing a 1g B16 in an OBD1 car? You will need a coolant fan switch harness connector from any 88-91 civic/crx to hook your fan switch wiring up correctly. The other sensors should pretty much plug in. PM me if you have questions.
ddbraungart
Honda CR-V & Element
Feb 24, 2018 08:34 AM
f22b2
Aug 18, 2017 10:40 AM
JDMislander
Mar 26, 2010 06:01 AM
Atheist
Apr 18, 2004 10:14 AM
NtgraTrboWanaB94
Mar 31, 2003 07:50 AM
