Ignition Breakdown
Old Jul 12, 2001 | 01:42 AM
Big James's Avatar
New User
Default Ignition Breakdown
OK, maybe someone can give me some ideas. A week ago, out of the blue, my car started running like crap. Backfiring, sputtering, stalling, surging, yada yada yada. Well, I yanked the plugs, to see the electrodes eaten away pretty bad. I threw in a new set of plugs, and the problem seemed to go away. However, the car is still trying to die at idle. The RPM's will dip very low. The car still does not "feel" right either. It seems to be running fine, but I can tell that it is not. I am thinking that I am havin some sort of ignition problem mainly becuase of the horrible shape of the last plugs, and the fact that it just happened while driving. It was running great, and then bang.
The motor is a 97 H22A4. The ignition upgrades consist of MSD 6A, Crane Cams PS91 Coil, and Vitek wires. I am thinking about replaceing the coil and wires, since these are relatively cheap, just to see if it improves at all.
If any of you have had a problem like this, let me know. Even if it was not related to the ignition, let me know what it was.
Thanks in advance.
Old Jul 12, 2001 | 11:06 AM
Leo95SE's Avatar
Default Re: Ignition Breakdown (Big James)
sup BJ.
I would change wires and cap, maybe coil.. shouldnt matter tho.
also - arent you running nos? i would run much colder plugs than stock...
HTH
Old Jul 12, 2001 | 12:15 PM
sohc_boy's Avatar
msd boxes have a history of failing u might wanna try bypassing your ignition box.
Old Jul 12, 2001 | 06:06 PM
976's Avatar
976
New User
Default Re: Ignition Breakdown (sohc_boy)
I would like to blame it on your wires, go for magnecor KV85 wires insted of vitek; they are more fashion then function.
sohc_boy had a good idea, bypass your MSD 6A box and run car, see if that is the problem.
[Modified by prsi, 3:06 AM 7/13/2001]
Old Jul 13, 2001 | 01:55 AM
Big James's Avatar
New User
Default Re: Ignition Breakdown (prsi)
Thanks guys. I am going to try to change out the wires. Hopefully I can find a set of Magnacore somewhere. If that does not work, I will bypass the ignition. I sure hope it ain't that because I have already had a Crane go out on me! Hopefully it is just the wires or the coil. The dist and cap are all about a year old. I bought them new when I bought my motor.
As for the plugs, I went back to stock just for the time being. I will be changing back to a colder plug once I figure out what the hell is wrong with this car!
Thanks again guys.
dantamparacer
Jun 28, 2012 03:46 AM
crazyrida
Sep 19, 2007 02:10 PM
THEDirtyDseriesWOOT
Oct 2, 2006 04:52 PM
keepitngga1
Dec 22, 2005 01:00 AM
SpoolnG2
Jun 26, 2004 03:55 AM
