Good high milage oil recommendations?
Old May 20, 2003 | 07:46 PM
sacredc0w69's Avatar
Default Good high milage oil recommendations?
Hey, i got a 90 accord LX, 5spd, its got a **** load of miles on it
like 215k miles? watever 332k km is do the math lol i dunno what the mile/km ratio is...
but anyway any1 got any suggestions on what is a good type motor oil to use? i use quaker 5w30 now mixed with synthetic oil....any suggestions on what would be good for such high milage to increase engine life ( ifstill possible )?
Old May 20, 2003 | 08:04 PM
any help?
what's best to use? anyone?
Old May 20, 2003 | 08:34 PM
89_LXi's Avatar
Default Re: (sacredc0w69)
Well it all depends on what shape your motor is in. High mileage doesn't always mean it's in bad shape, and low mileage doesn't always mean it's in good shape. 332k KM = ~199,200 miles, BTW. If your motor is in good shape, and doesn't leak or burn any oil, I would suggest a good synthetic like Mobil 1..... good stuff . I've been using Mobil 1 for several years in my currently 317,500 mile motor which has never been rebuilt, and it works great with no problems. Still doesn't burn or leak a damn drop. However if your motor isn't in the greatest shape, then a little thicker conventional might be the way to go. I've heard some ppl say to stay away from Quaker State and Pennzoil (??), but personally I've never had any prob with any name brand conventional oil. Some brands have a 'high mileage' formula which is a lil bit thicker, which may be worth a try.
Old May 20, 2003 | 08:46 PM
mobil 1 eh...
is it 5w30 or 10w30 or wat?
sorry i dont know my oils very well
uh...i dont think the engine is in the greatest shape...i got oil in on the spark plugs so its leaking threw somewhere...either my pistons are farked or my valves...i'm gonna get aroudn to checking it cuz i need to find out soon, its not burning oil thats for sure
anyway just fill me in on that mobil1 stuff and i'll giver a try next time i change my oil
Old May 20, 2003 | 09:21 PM
89_LXi's Avatar
For me, being in hot *** south Florida, I use 10w-30 year round. For you though being in Canada, I'd use 5w-30 (thinner) in winter, and 10w-30 (thicker) in summer. If it doesn't get real super hot you could probably use 5w-30 year round.
Just so you're not too shocked, Mobil 1 is about $4.50/qt US, so it's kinda expensive. Good oil though
Old May 21, 2003 | 12:30 AM
georgeda's Avatar
Default Re: Good high milage oil recommendations? (sacredc0w69)
If you have any leaks or burn some oil I suggest one of the newer oils that are formulated for high milage engines. I have been using Valvoline high milage oil in my Dodge truck that was leaking and using oil. It has helped quite a bit. Valvoline was the first with high milage oil and now I see many other major brands have come out with high milage oil.
Old May 21, 2003 | 08:18 PM
i c, the oil didn't help with the leak or anything did it? lol
i think my cars leeking oil somewhere not sure where though...and it only burns oil when i rev really high (5000-6000rpm) other than that its fine lol
Old May 22, 2003 | 04:46 AM
YeuEmMaiMai's Avatar
use the oil recommended for the car.
Old May 22, 2003 | 04:23 PM
::MYCORD::'s Avatar
Default Re: (YeuEmMaiMai)
This site will answer anyone's questions about oil. http://theoildrop.server101.com/cgi/ultimatebb.cgi
Old May 23, 2003 | 12:11 PM
RotaryBzzz's Avatar
Default Re: Good high milage oil recommendations? (georgeda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgeda &raquo;</TD></TR><TR><TD CLASS="quote">If you have any leaks or burn some oil I suggest one of the newer oils that are formulated for high milage engines. I have been using Valvoline high milage oil in my Dodge truck that was leaking and using oil. It has helped quite a bit. Valvoline was the first with high milage oil and now I see many other major brands have come out with high milage oil.</TD></TR></TABLE>
Interesting. Did you find that it burned less than regular Valvoline? Did the leaks go away?
Old May 23, 2003 | 01:45 PM
Default Re: (mycord)
just reading some of those threads overthere about various engine problems in american cars makes me glad i own a honda.....
Old May 24, 2003 | 01:13 AM
georgeda's Avatar
Default Re: Good high milage oil recommendations? (RotaryBzzz)
I said my Dodge truck was "leaking and using oil" and "helped quite a bit". I mean the leaking and using oil were reduced - not completely eliminated.
For more information read the package lable and contact the manufacturer.
Old May 24, 2003 | 06:07 AM
philipkrotch's Avatar
ive been using valvoline max life since i had 175 k on my 4th gen..i now have 218k on it and compression is 170 psi in all 4 cylinders. good as new. never rebuilt either. i swear by valvoline max life.
Old May 24, 2003 | 11:43 AM
davglt's Avatar
with that many miles I would ot switch anduse an synthetic, you may have seal problems, stick with a good mineral base like Pennzoil, Valvoline, etc. and it willb e fine, if its wram use 10-30, cold use 5W30.
therhett17
Dec 18, 2016 12:08 PM
akire45
13
Jul 6, 2009 02:20 PM
SoCal_81
Jan 25, 2008 02:23 PM
AllMoToRB18c
Jul 4, 2003 10:28 AM
BlackGSR
May 4, 2002 09:17 AM
