help: A/C repair
Old May 20, 2003 | 03:55 PM
boot machine 5000's Avatar
Default help: A/C repair
the low-pressure suction hose on my a/c is leaking and it needs to be replaced. is this any difficult to do? it looks like it just bolts on. also is there any special sealant i need? please help, damm mechanics were ripping me off in this install, ill rather do it myself. thanks.
Old May 20, 2003 | 07:43 PM
Default Re: help: A/C repair (Alvin)
anyone
Old May 20, 2003 | 08:38 PM
blah13's Avatar
On my a6 its damn simple, the hose unbolts from the firewall and then around the radiator. Just trace it to where the other end is. Then replace the 2 small o-gaskets and you should be set.
Old May 20, 2003 | 08:43 PM
tilt's Avatar
I've replaced an a/c line in my maxima before. If its anything similar then it is very easy to do. Just use a wrench and remove a couple nuts. Did you figure out the exact cause of the leak? Chances are its just a bad O-ring. You can spray soapy water on the connector and see if it bubbles if it's leaking bad. Also if you expose the drier by removing the line then the a/c will probably smell like mildew or fish. so you may want to replace that as well.
Old May 21, 2003 | 02:16 PM
Default Re: help: A/C repair (tilt)
i just replaced the hose, it was pretty simple. i got a little scared when i took it off cuz there was still a little presure in the system, hehe. its all good now, now i just need to fill it with freon and im set for the summer. thanks guys
PatrickGSR94
Aug 12, 2008 09:52 AM
txracer
Aug 24, 2005 08:58 AM
vtec69
Mar 28, 2003 06:41 PM
f1YONSdc2
Jan 20, 2003 07:05 PM
integrx
Apr 8, 2002 07:21 PM
