? For allmotor guru's
Old May 20, 2003 | 06:28 AM
EG-cellent's Avatar
Default ? For allmotor guru's
Just wondering what size injectors and fuel pump I'm going to need? Also would like a little more info on which cams to run? This car will be for semi daily driving an drag and maybe a little bit of SCCA.
Here is my setup.
b16 block GE sleeved bored 84mm
Je 12.5.1 comp. pistons
eagle rods
micropolished and champhered (sp) crank
alaniz p/p head w/ highlift valve springs and retainers
jun 3, toda c's, or ef-1 camsneed more info on these
skunk2 IM with 68mm or 70 mm t/b
HeaderTech header
AEM CAI
JDM ITR or Y21 trans with 4.78 and lsd
clutchmasters flywheel and stage 3 clutch
All to be tuned w/ Hondata or AEM EMS
Thanx in advance.
Old May 20, 2003 | 06:30 AM
CHEETAH's Avatar
Default Re: ? For allmotor guru's (EG-cellent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-cellent &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering what size injectors and fuel pump I'm going to need? Also would like a little more info on which cams to run? This car will be for semi daily driving an drag and maybe a little bit of SCCA.
Here is my setup.
eagle rods
HeaderTech header
AEM CAI
at least 310cc injectors, 55psi fuel pressure and walbro 195lph or supra/rx7 fd3s/mitsu 2liter turbo fuel pumps
greg
Old May 20, 2003 | 06:54 AM
EG-cellent's Avatar
Default Re: ? For allmotor guru's (CHEETAH)
Would 370's be overkill and should I run an intank pump or inline one?
Thanx
Old May 20, 2003 | 07:13 AM
crazyitr's Avatar
I have almost the exact same setup and i was advised to use 270 or 310 cc injectors. If you plan on using Hondata go up to 440's, you'll just run a lower duty cycle (ie your injectors won't work as hard). My motor will go together in 3 weeks, except i have 84.5 mm sleeves.
Old May 20, 2003 | 07:22 AM
NSX Bob's Avatar
New User
I use 310's w/ a somewhat similar seup. If you get a hondata, there will be no such thing as overkill as far as the injectors are concerned.
Old May 20, 2003 | 08:32 AM
dfoxengr's Avatar
just get 370s and 255LPH intank...
Old May 20, 2003 | 09:30 AM
EG-cellent's Avatar
Default Re: ? For allmotor guru's (hybridvteceg)
What other things would you do to or change about my setup?
Old May 20, 2003 | 10:37 AM
dfoxengr's Avatar
what would i change, lol this is not for you but:::
b16 block GE sleeved bored 84mm CHANGE
Je 12.5.1 comp. pistons CHANGE
eagle rods CHANGE
micropolished and champhered (sp) crank CHANGE
alaniz p/p head w/ highlift valve springs and retainers CHANGE
jun 3, toda c's, or ef-1 camsneed more info on these CHANGE
skunk2 IM with 68mm or 70 mm t/b CHANGE
HeaderTech header CHANGE
AEM CAI CHANGE
clutchmasters flywheel and stage 3 clutch CHANGE
thats me though..i would telly uo what id change it to, but thats my motor setup, lol..shh
Old May 20, 2003 | 11:54 AM
EG-cellent's Avatar
Yeah that was really helpful
it all good though!
Old May 20, 2003 | 11:57 AM
joe_bocc's Avatar
As for your cams, I personally think that Toda c's are a little too much for the street, but that just me. The JUN 3's are a little more tame so they would be my choice.
Old May 20, 2003 | 12:42 PM
SlowPoke's Avatar
New User
Default Re: ? For allmotor guru's (joe_bocc)
you should be fine with 310's I don't see any need for any bigger on that setup.
Old May 20, 2003 | 12:58 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-cellent &raquo;</TD></TR><TR><TD CLASS="quote">What other things would you do to or change about my setup?</TD></TR></TABLE>
ha thats y u asked me what I would do lol...
Old May 30, 2003 | 11:33 AM
Lip's Avatar
Lip
https://honda-tech.com/zeroforum?id=44
EFbomb
Oct 31, 2007 11:36 PM
GrimLude
14
May 2, 2006 01:33 PM
h22 vtec lude
Aug 29, 2005 12:11 PM
EG-cellent
Jun 6, 2003 08:47 AM
