OEM exhaust gasket & boost?
Old May 19, 2003 | 08:25 PM
XES's Avatar
XES
Default OEM exhaust gasket & boost?
Anyone running the OEM exhaust gasket with boost (either high or low boost)?...or are people using Mr.Gasket copper gaskets instead?
Old May 19, 2003 | 08:29 PM
b16ahybrid's Avatar
Default Re: OEM exhaust gasket & boost? (XES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES &raquo;</TD></TR><TR><TD CLASS="quote">Anyone running the OEM exhaust gasket with boost (either high or low boost)?...or are people using Mr.Gasket copper gaskets instead?
stock for me, seems to work fine.
Old May 19, 2003 | 08:37 PM
XES's Avatar
XES
Default Re: OEM exhaust gasket & boost? (b16ahybrid)
Any higher hp cars?
Old May 19, 2003 | 08:45 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES &raquo;</TD></TR><TR><TD CLASS="quote">Any higher hp cars?</TD></TR></TABLE>
What is mine not worthy?
Old May 19, 2003 | 08:50 PM
XES's Avatar
XES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">What is mine not worthy? </TD></TR></TABLE>
...that's not what I meant ....I was just wondering if an OEM would be good at 22-25psi and 500+whp. I was running a copper one last year but I need to replace it and was wondering if stock would do.
Old May 19, 2003 | 08:54 PM
b16ahybrid's Avatar
...that's not what I meant ....I was just wondering if an OEM would be good at 22-25psi and 500+whp. I was running a copper one last year but I need to replace it and was wondering if stock would do.</TD></TR></TABLE>
ok, just checking... ...
I don't see why it wouldn't work with that much boost, it is metal. I don't have any factual knowledge for you though just oppinion.
Old May 20, 2003 | 02:22 PM
XES's Avatar
XES
anyone else?...what no turbo guys here?
Old May 20, 2003 | 02:27 PM
silverEH2's Avatar
LOL........stock for me but i am not in the 500 hp club
Old May 20, 2003 | 02:30 PM
BlackB18CTeg's Avatar
a stock should work fine...... unless you use a specific gasket which drops compression, as long as its sealed up right it should work. Aslong as its torqued right a gasket is a gasket.......
Old May 20, 2003 | 07:07 PM
TurboSedan's Avatar
New User
Default Re: OEM exhaust gasket & boost? (BlackB18CTeg)
Stock on the exhaust mani and stock for the head as well on my car. Works fine for me.
Old May 20, 2003 | 07:23 PM
BOOSTED 4DR. GS-R's Avatar
Default Re: OEM exhaust gasket & boost? (TurboSedan)
I run copper mr.gasket. I have ran it fo 2 years now no problems...
johnsc2235
Mar 16, 2008 10:03 AM
jarven093
Mar 3, 2007 10:39 PM
invisible
Feb 5, 2007 05:25 PM
H22Luda720
Mar 6, 2006 07:13 PM
Turbocivic94
Feb 26, 2006 02:18 PM
