What headgasket for 84.5mm?
I have B20 with 84.5mm Darton sleeves and I wanted to know which headgasket I should run. It will be high boost motor.
Re: (xsi-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsi-t »</TD></TR><TR><TD CLASS="quote">what if u have a gsr with 84mm what headgasket then??</TD></TR></TABLE>
golden eagle
golden eagle
Munkyw3rkz.webs.com
1 Post
Re: (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">I shouldnt worry about using oem 84mm gasket then</TD></TR></TABLE>
nope....thats the only thing i have used on all my set ups...
last one was a 85mm LS stock head gasket
Re: (Turbocivic94)
the GE gasket is OEM. its just punched out to whatever size you need
Re: (86si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si »</TD></TR><TR><TD CLASS="quote">
the GE gasket is OEM. its just punched out to whatever size you need</TD></TR></TABLE>
I knew the ge is puched out but only reason I asked this question due to future refrence also just in case I blew a head gasket and needed one right away. I was gonna buy a ge but if stock oem B20 would work then I'm just gonna run that cause it will probably be cheaper and easier to find.
eg2oreg6watuwant
13
10-24-2007 09:51 PM
Nisif
14
03-12-2006 11:00 AM
Master23
03-08-2006 01:18 PM
Bigjussin
11
04-16-2005 02:57 PM
