b16 sir2 swap into 5th generation civic ex
I am planning on swapping a b16 sir2 into civic ex 5th generation. What wire harness do I use since the JDM harness that came with the setup is useless? What parts do I need in the scenario above?
Also, since the throttle body does not contain an external map sensor (built into t-body), how do I work around this ? How about if I was to go with a ITR throttle body?
Anybody have any help or suggestions ?
Guest
Posts: n/a
First off, you should have searched this topic, I'm sure there's hundreds of posts on this.
Since you didn't here's some answers.
1- Use you EX harness and add the knock sensor wires or go buy a P30 (USDM delSol DOHC VTEC) harness.
2- Get a 94-95 T-body off a LS or GSR. OR, you can use the 98+ ITR T-body.
roro1
Sep 27, 2013 10:44 PM
