EGTS hitting 1600 degrees while going down the track!
Old May 17, 2003 | 02:54 PM
turbo Si's Avatar
Default EGTS hitting 1600 degrees while going down the track!
Is this normal? The car is running great, but I can't help but notice the egts hitting 1600 at high boost (23lbs). I am using an Autometer guage and probe. It's not the cheap probe either ($99.00) . What do you guy's think? Alex (GSRev) told me his hit's that high as we'll while going down the track.
Old May 17, 2003 | 03:03 PM
metal-x's Avatar
Default Re: EGTS hitting 1600 degrees while going down the track! (turbo Si)
where did you mount the probe?
Old May 17, 2003 | 03:41 PM
turbo Si's Avatar
Default Re: EGTS hitting 1600 degrees while going down the track! (metal-x)
#3 runner. It works fine. I just wanna see if it's common for it to hit that high?
Old May 17, 2003 | 04:49 PM
TeStUdO's Avatar
how much is your timing retarded when the boost is that high????
Old May 17, 2003 | 09:12 PM
turbo Si's Avatar
Default Re: (TeStUdO)
19-20 degrees.
Old May 18, 2003 | 05:26 AM
QCKGSR's Avatar
Default Re: (turbo Si)
what is your total timing at that boost... should be around 24-26
Old May 18, 2003 | 08:01 AM
16vracer's Avatar
1600 isn't that hot. I've hit 1800 before on a 4th gear 25psi dyno pull
Old May 18, 2003 | 04:22 PM
turbo Si's Avatar
Default Re: EGTS hitting 1600 degrees while going down the track! (16vracer)
Yeah but that's one pull. I'm talking about going down the track through 3, 4, and 5th gears at 1600 or more. Isn't 1500 something boing point for aluminum forged pistons?
Old May 18, 2003 | 08:39 PM
Hispeed's Avatar
My egt is right out of the cylinder head and yes it does tag the 1600 mark, but my air/fuels ratio is right on target. So don't go just by your temps. Check your plugs and look for signs of detenation.
Old May 19, 2003 | 03:25 AM
turbo Si's Avatar
Default Re: EGTS hitting 1600 degrees while going down the track! (GSRev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRev &raquo;</TD></TR><TR><TD CLASS="quote">My egt is right out of the cylinder head and yes it does tag the 1600 mark, but my air/fuels ratio is right on target. So don't go just by your temps. Check your plugs and look for signs of detenation. </TD></TR></TABLE>
Hmmm, I guess your right. Last thursday the car ran great, and the plugs looked good. I don't know, I guess i'm stuck with the thought of something going wrong around that temp.
Snailor Built
Jul 27, 2013 09:41 AM
laziebun
Engine Management and Tuning
Jan 26, 2009 03:43 AM
96vtecI4
Mar 6, 2007 10:07 PM
scttydb411
May 18, 2004 07:06 PM
shamoo
Sep 30, 2002 06:38 AM
