Cant get back rotord off!!!!!!!
Old May 13, 2003 | 08:00 PM
forcedaccord95's Avatar
Default Cant get back rotors off!!!!!!!
hey guys,
95 honda accord
im doing new rotors, pads and braided brake lines. I got the front done, but have ran into a problem with the rear. the rear rotors are held on by two phillips head screws. i used and impact driver to try and break them loose, but no luck!
i have stripped one out of the four, what should i do. i tried penitration oil and no luck! i was told to drill, but the only problem is that the type of screw would be impossible to match, the screw set flush with the rotor. any recomendations?
thanks
shane
Old May 13, 2003 | 08:04 PM
Stripped Honda's Avatar
99-0104
Default Re: Cant get back rotors off!!!!!!! (forcedaccord95)
dont use the screws again ... they are just to hold the rotor in place till your rim is installed many people here on honda tech dont use them at all because they always strip out ... to get it off i use a nailset and hit it counter clockwise will it unscrews itself ...
Old May 13, 2003 | 10:51 PM
Steve04SVT's Avatar
Default Re: Cant get back rotors off!!!!!!! (Stripped Honda)
If you really need another screw, then just contact your local Honda Dealership Parts Depart. and see if they have some in stock. May cost a bit, but at least you have the correct one.
Old May 14, 2003 | 12:36 AM
B2FiNiTY's Avatar
You can get the screws at the dealer.
Old May 14, 2003 | 03:28 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Cant get back rotors off!!!!!!! (B2FiNiTY)
I bought 4 new ones from the dealer for like $.38 each. Also, those screws are a one time use only.
Old May 14, 2003 | 05:08 AM
Chiovnidca's Avatar
Default Re: Cant get back rotors off!!!!!!! (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">Also, those screws are a one time use only.</TD></TR></TABLE>
No their not, they can be used over if you don't screw them up. Where did you come up with that?
Old May 15, 2003 | 03:08 AM
H-T Order of Merit
Default Re: Cant get back rotors off!!!!!!! (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
No their not, they can be used over if you don't screw them up.</TD></TR></TABLE>
I suppose you could but they're pretty hard not to screw up when they're in there as tight as they usually are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Where did you come up with that? </TD></TR></TABLE>
In the Helms. It says to replace them.
Old May 15, 2003 | 03:48 AM
Chiovnidca's Avatar
In the Helms. It says to replace them.</TD></TR></TABLE>
Which Helms? What page? I don't see it.
Old May 15, 2003 | 06:25 AM
YeuEmMaiMai's Avatar
the only reason I can see to replace them
your rear brakes will last over 100K and by that time you have to beat the crap out of them to work em loose it is less that $2 so not a biggie
your front brakes provide 90% of your car's stopping power so if you want better stopping distance upgrade to V6 brakes.
Old May 15, 2003 | 03:15 PM
99-0104
Default Re: Cant get back rotors off!!!!!!! (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">the only reason I can see to replace them
your front brakes provide 90% of your car's stopping power so if you want better stopping distance upgrade to V6 brakes.</TD></TR></TABLE>
get your facts straight before yapping front brakes dont do 90% of the stopping from what i remember it is 2/3rds ( not totally sure but i know it isnt 90%)
and the screws do nothing just hold the rotor in place .... your rim also does that once they are installed so the screws are useless..... it is safe with them or without them .....
Old May 17, 2003 | 06:13 PM
thats cool and all, but i cant get them off at all, they are completely stripped, should i drill and retap?
Old May 17, 2003 | 06:21 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcedaccord95 &raquo;</TD></TR><TR><TD CLASS="quote">thats cool and all, but i cant get them off at all, they are completely stripped, should i drill and retap?</TD></TR></TABLE>
Just drill them out. You can do without them.
faran
Apr 12, 2013 05:58 PM
JBirch_97Prelude
Jun 25, 2008 05:25 PM
93CamaroLT1
May 31, 2006 05:49 PM
B18EG6
Jul 8, 2004 07:37 AM
Rywire
10
Jan 12, 2004 11:50 AM
