sick and tired of babying 3rd gear...
Old May 13, 2003 | 05:29 PM
h22a193's Avatar
Default sick and tired of babying 3rd gear...
Im sick of this crap, why cant I slam third gear anymore? I used to do it perfect all the time, but now when I shift at redline or any rpm to third it wont let me in for like a second. Feels like theres a wall there or somthing, I shift in anyother gear fine, but third is different. I just chaged my fluid 6,000 miles ago. It grinds somtimes to when I force it in, even when the clutch is all the way in? What should I do.
I cant stand it anymore, how much are trannys!
Old May 13, 2003 | 06:22 PM
PetroGuyX's Avatar
well, it sounds like you let the clutch out before you finish "slamming" and grind the **** out of it everytime so now it's hard for you to get it in gear, i've done it before, mine is actually a little like that, so i stopped "slamming"
Old May 14, 2003 | 02:48 PM
h22a193's Avatar
do you think I need a clutch?
Old May 14, 2003 | 04:02 PM
str8rcn's Avatar
Default Re: (h22a193)
Mine did the same thing starting at about 115000 miles.Then a trip to the track with drag radials and boom,no more tranny.Not saying yours is going out but how many miles are on it.Also you might want to look into Syncro Shift.Its really good stuff.Its an additive weve used many times and it almost always helps.
Old May 14, 2003 | 04:46 PM
TimeRacer's Avatar
Default Re: (str8rcn)
You bent your shift fork and possibly have a fried syncro. There's nothing you can do about it unless you pull the transmission and replace the fork and syncro set. I have no idea why you're slamming the gears around all the time anyway. If it doesn't go, it doesn't go. You forced it one too many times.
Old May 14, 2003 | 05:40 PM
PetroGuyX's Avatar
how would a clutch help you?
Old May 14, 2003 | 06:49 PM
XxRONNxX's Avatar
New User
Default Re: (PetroGuyX)
I have a similar problem. I had the wall problem before. Now it grinds. 3rd gear grinds when I shift at high RPMs. All the other gears are fine. It shifts fine into 3rd at lower RPMs.
Old May 14, 2003 | 08:04 PM
XcreatonX's Avatar
my friends civic grinded into gears for a while then they just went out so hope you dont have the same problem
my clutch went out and syncros and im rebuilding it so hopefully it will be nice and normal
Old May 18, 2003 | 02:57 PM
94PreludeSi's Avatar
Yeah it sounds like a bad synchro/ bent shift fork.... consider yourself luck though.. DSM shift forks dont bend, they just snap..... Im on tranny #3 in less than 10K miles..
JDMGSR-T
Oct 27, 2006 02:48 PM
silent-chris
Honda S2000
Sep 17, 2006 09:00 PM
SatinSilver_DC5
May 3, 2005 05:29 AM
B18cteg
Jul 3, 2003 10:18 AM
hondafrk
Jun 29, 2002 10:53 PM
