Type R delsol
Old May 11, 2003 | 11:16 AM
basspro141's Avatar
Default Type R delsol
Has anyone tried to or succeded at putting a new b18c r which is the jdm type r motor in a 95-97 delsol any tips i need before going about this . motor was sent from osakajdmmotors directly from japan with tranny and ecu exc....... motor is getting built as we speak you know billit conecting rods je pistons 9:1 lets just say around 14000 dollars in to building the engine when it comes hoem it gets rev hard turbo sitting in garage anyone one can help me with some swap tips i apreaciate it
Old May 11, 2003 | 11:25 AM
DaveF's Avatar
Default Re: Type R delsol (basspro141)
if you are building an engine like that, and have no idea about a simple swap, you dont deserve what you have or are getting.
the engine and trans will bolt in using 94 and up integra mounts along with the axles, shiflinkage, you should get a custom ecu and a gsr wiring harness or modify your existing wiring harness.
Old May 11, 2003 | 12:24 PM
skribblah's Avatar
Default Re: Type R delsol (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">if you are building an engine like that, and have no idea about a simple swap, you dont deserve what you have or are getting.</TD></TR></TABLE>
i concur
Old May 12, 2003 | 09:38 AM
basspro141's Avatar
well accually i was just asking if anyone had done that swap thats all and hosport makes motor mounts for my car i have a type R wire harness and tranny i have everything i need 94 axels will not handel 400 horse as far as not deserving the motor dont be jealous
Old May 12, 2003 | 09:39 AM
.RJ's Avatar
.RJ
try to word your questions better, you'll get a better response
Old May 12, 2003 | 10:26 AM
msilbernagel's Avatar
Is your engine harness the JDM or USDM one? If it is the one that came on the car, it is 'backwards' -- connectors on the opposite side. Since you have a JDM ecu, the sensor differences shouldn't be a problem, but adapting a USDM harness will take a little studying (or experience). Nothing you can't handle.
Ask me in another month or so... The experience should be fresh by then.
Mark
Old May 14, 2003 | 02:16 PM
basspro141's Avatar
Default Re: Type R delsol (msilbernagel)
the harness is jdm everything is jdm i got everything from osakajdmmotors.com
Old May 14, 2003 | 03:27 PM
VTEC-DA's Avatar
Does the 14000 include the cost of the engine? Even if it does, what in the hell are you spending 14000 on?
Old May 14, 2003 | 07:37 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by basspro141 &raquo;</TD></TR><TR><TD CLASS="quote"> as far as not deserving the motor dont be jealous </TD></TR></TABLE>
hahahaha, that's got to be the funniest thing i read all day....thanks for the laugh..cause your a joke....14,000 on a b18c "r"......
i know its hard to find but there is a search button around here somewhere..... also, if you are trying to put that engine in your car its about the same as gsr minus the butterflies on the intake mani..use an obd1 computer and obd1 gsr distributer. modify your stock harness...its a piece of cake and shuld take no more than 2 hours to modify it and have it lookin all pretty
WOAH watch out..terror on the streets... HA HA HA
Old May 14, 2003 | 08:04 PM
spun Vtec's Avatar
im shure you are the only one that has ever done a c5 in a del sol
you my friend (and your dad who prob bought it) are paveing the way to new heights of import proformance of which lesser foke such as me and other's on honda tech would never be able to understand. thank you for the humor of putting "14 grand" into a c5 and putting it in a uglyass 4000lb car such as the honda del sol im shure the red shien of the valve cover will clash nicely with the sparkeling altezzas
Old May 14, 2003 | 08:21 PM
MADEINIRAQ's Avatar
Default Re: Type R delsol (spun Vtec)
is it really 4000 pounds... i'd like to know.. they are so cute though
Old May 14, 2003 | 10:55 PM
.RJ's Avatar
.RJ
Default Re: Type R delsol (madeiniraq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madeiniraq &raquo;</TD></TR><TR><TD CLASS="quote">is it really 4000 pounds... i'd like to know.. they are so cute though </TD></TR></TABLE>
No, but the chassis is about as stiff as one of those big wheels cars (you know the ones with the red body and yellow top)
Old May 15, 2003 | 02:40 AM
DaveF's Avatar
Default Re: Type R delsol (.RJ)
whatch out guys....he says everything is jdm.....i guess that makes it fast
Old May 15, 2003 | 03:20 AM
hanson said's Avatar
del sol's are around 24-2500lbs
Old May 15, 2003 | 08:18 AM
AzntaggeR's Avatar
TSPeed Factory
2295 lbs. i don't know why everyone thinks they're heavy.
Old May 15, 2003 | 06:40 PM
drumking15's Avatar
because i beleive theyre heavier than hatch...less car = more weight just doesnt make sense....if i was gonna buy a 2 seater it be a turbo mr2, forget the delslo...even tho i do love hondas
Old May 17, 2003 | 03:18 PM
basspro141's Avatar
Default Re: (drumking15)
14000 includes the motor all the work my suspension and the car as a matter of fact my father had no part in this car . i realize that there are alot of people out there that are jealous but its ok none of that matters when i blow bye you on the highway like you were stoped
Old May 17, 2003 | 03:36 PM
Lost Type R's Avatar
Default Re: (basspro141)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by basspro141 &raquo;</TD></TR><TR><TD CLASS="quote">14000 includes the motor all the work my suspension and the car as a matter of fact my father had no part in this car . i realize that there are alot of people out there that are jealous but its ok none of that matters when i blow bye you on the highway like you were stoped
First, no one cares if you have the "almighty type r" motor in that del sol, there are shitloads of people on these boards that have em. Second, you must be another one of those trolls.
Post pics of reciepts and prove to us you really are spending 14k. Third, you do NOT deserve a motor like that if you are gonna do ricer flybys on the freeway.
Old May 17, 2003 | 03:40 PM
ERA's Avatar
ERA
Default Re: (Lost Type R)
Just so everyone knows, These types of people DO NOT represent DelSol owners..... remember... It's STILL a Honda
toqeer1986
16
Jun 7, 2011 03:21 PM
browntown jdm
20
Sep 25, 2010 05:13 AM
Nikademo
Apr 19, 2010 08:02 PM
chrisquin23
Honda S2000
46
Nov 23, 2008 07:48 PM
Sasha1012
May 5, 2003 08:46 AM
