Ignition system worth it?
Old May 11, 2003 | 02:36 AM
Ottoman's Avatar
Default Ignition system worth it?
MSD control
MSD Coil
MSD CAP
Wire Set
Spark plugs
Total: $450
is an ignition system worth this kinda cash? or it only helps when u're boosting high/high compression pistons etc.?
Old May 11, 2003 | 05:44 AM
StyleTEG's Avatar
Default Re: Ignition system worth it? (Ottoman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ottoman &raquo;</TD></TR><TR><TD CLASS="quote">
it only helps when u're boosting high/high compression pistons etc.?</TD></TR></TABLE>
There is a 10 second LS/Vtec civic running stock ignition.
Old May 11, 2003 | 08:52 AM
b19coupe's Avatar
Don't waste your money. A properly maintained stock ignition system is more than adequate for most engines. Speed the money on something that will actually improve your hp/tq.
Old May 11, 2003 | 11:56 AM
psi420's Avatar
Yah, i would wait till you atleast have turbo or NOS!
Yeah, whatever, I do what I want!
NAWS, NOS, NAAAWWWSSSSSSS!!!!!!!!
Old May 11, 2003 | 12:07 PM
NonovUrbizniz's Avatar
Loved
Default Re: (psi420)
I'd skip the box and wires... just get the cap and coil... it'll be the same improvement as with the box...and the box is ALL of that cost.
the coils can be had for 20 bucks and cheaper for the modifier cap.. I got one and I'm sure replacing my stock coil would have improved the car as much but I'm MORE than happy with the coil/cap combo.. it's kinda a pain to run the wires under the cap but... that's life.
Old May 11, 2003 | 01:10 PM
civicsitek GanGsTa's Avatar
Default Re: (NonovUrbizniz)
I believe Erick's Racing all motor civic coupe runs stock ignition.
Old May 11, 2003 | 05:50 PM
sspikey's Avatar
Default Re:
amazed stock honda ignition can take this. our sr20det's in nissan world can take 450WHP (farthest ive seen it taken to) and didnt miss at all. hats off to honda.
Old May 11, 2003 | 10:17 PM
warwagon's Avatar
erick aguilar 10.07 all motor stock ignition, 450 not needed to spend
92civlude
May 15, 2009 07:45 AM
LSV_REX
Aug 29, 2007 08:30 AM
JDM_COUPE94
15
May 3, 2007 03:05 PM
blaze the chemi
Oct 28, 2005 05:02 AM
budget
Apr 17, 2005 09:17 PM
