MSD Ignition
Old Aug 28, 2007 | 05:49 AM
LSV_REX's Avatar
Default MSD Ignition
So I have a built Naturally Apirated LSVTEC, Buddy Club SpecIV's, CTR Pistons etc, ARP etc, this is not a thread to flame on the LSVTEC. I'm wondering if I should stay with the stock coils or go with a box and coil from MSD or maybe even just a coil. I heard stock ignition is good for up to 400hp but I'm afraid with such high compression 12.68:1 with the thicker headgasket.
Modified by LSV_REX at 9:23 AM 8/28/2007
Old Aug 28, 2007 | 06:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: MSD Ignition (LSV_REX)
50% will tell you msd is good 50% will tell you msd is bad 50% will tell you nothing pertinent at all.
it works for some people, and not for others, me it has worked for 6+ years. with the exception of my coil crapping out on me thats the only issue i have had.
with that compression, i thikn you will need a hotter coil and a box wont hurt.
Old Aug 28, 2007 | 06:14 AM
Aggressive Racing's Avatar
Default Re: MSD Ignition (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">with that compression, i think you will need a hotter coil and a box wont hurt.</TD></TR></TABLE>
Yes and do a Digital box not that analog crap.
Old Aug 28, 2007 | 06:24 AM
Turbo-charged's Avatar
Default Re: MSD Ignition (Aggressive Racing)
ive had good luck with the digital systems.
Old Aug 28, 2007 | 06:40 AM
uglyasscivic's Avatar
Default Re: MSD Ignition (Turbo-charged)
I have an MSD Digital 6 in my car. They can work well just make sure it is mounted in the car away from the ECU. I Have had this current box for about 5 years now.
Old Aug 28, 2007 | 09:49 AM
jjspec's Avatar
Default Re: MSD Ignition (uglyasscivic)
Digital 6 and HVC coil in my ride, havent had any issues yet.
Old Aug 28, 2007 | 09:53 AM
LSV_REX's Avatar
Yeah but all you guys are a bazillion hp and run 9's. I'm thinking I don't NEED the box. Stock ignition though might not handle 8500rpm very well. I don't know 400 bucks for that box is steep.
Old Aug 28, 2007 | 09:55 AM
DaveF's Avatar
Default Re: MSD Ignition (jjspec)
we have been using the same MSD 7 series box in Steves car since the beging of 05. granted its a track only car, but its holding up for sure !
Old Aug 28, 2007 | 01:23 PM
SPOOLINmatt's Avatar
Default Re: MSD Ignition (DaveF)
i mount my msd 6al box right on the same board as my ecu and ive never had problems. 650-700whp.
I dont know why so many people have problems with it.
Old Aug 28, 2007 | 01:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSV_REX &raquo;</TD></TR><TR><TD CLASS="quote">Yeah but all you guys are a bazillion hp and run 9's. I'm thinking I don't NEED the box. Stock ignition though might not handle 8500rpm very well. I don't know 400 bucks for that box is steep.</TD></TR></TABLE>
So if you "think" you know what you need and what you're doing,why ask our opinions..
Old Aug 28, 2007 | 02:37 PM
2point2's Avatar
just wire in a backup.. they even have a friggen part to switch units. haha..
they do what they are supposed to do but it's no secret that it is hit and miss with their products.
It's actually quite amazing how far of a gap you can jump with the box and a coil.
Does anyone know what generally goes bad in these units?
Old Aug 28, 2007 | 02:43 PM
G2K's Avatar
G2K
Default Re: MSD Ignition (2point2)
Might have something to do with the fact most people don't mount the box right, using isolators. I've also seen alot of peeple mess up the wiring, or not power the box from a fused source and burn the box up with a short in the wiring.
Old Aug 28, 2007 | 03:23 PM
extremevtecracing's Avatar
I don't have anything crazy for my car, just a 6al with a blaster 2 coil and its been kicking for some time. The last thing that went on me was my Blaster SS coil. I actually liked it but it was 9 at night the only place open that had MSD was Vauto Zone and sacrifices had to be made. So i went with a Blaster 2. 475hp T1 tuned btw.
Old Aug 28, 2007 | 03:51 PM
Miss PSI's Avatar
I'm running stock ignition with 448whp and no problems. I actually had problems with my MSD blaster 2 coil.
Just my 2 cents
Old Aug 29, 2007 | 06:19 AM
LSV_REX's Avatar
Default Re: (Miss PSI)
Stock ignition and 448whp. I'm just concerned I'm going to have problems at 7500-8500 RPMS. Some people tell me I need MSD and some people say stock ignition. What are you revving to?
Old Aug 29, 2007 | 07:55 AM
Jay_Sensing's Avatar
I personally used a stock ignition ro 9400 rpm's for over 100 passes and around 5k miles of driving plus a **** load of dyno pulls.
NO issues what so ever with it.
I now use an MSD for ignition because I have to so I can use the MSD multi stage retard box for timing control on the bottle and have 0 issues with it. Stock was perfectly fine though prior to the nitrous.
Old Aug 29, 2007 | 08:03 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (Jay_Sensing)
Jay,
I'm wondering if you could use a two-timer instead the msd. The two-timer changes the ecu map via switch. You could have a complete NA map and a Boost (NOS) map switchable via the nos switch.
To the OP, stick with the stock ignition.
Modified by mar778c at 9:26 AM 8/29/2007
Old Aug 29, 2007 | 08:09 AM
Universal Magnetic's Avatar
Default Re: (LSV_REX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSV_REX &raquo;</TD></TR><TR><TD CLASS="quote">So I have a built Naturally Apirated LSVTEC, Buddy Club SpecIV's, CTR Pistons etc, ARP etc, this is not a thread to flame on the LSVTEC. I'm wondering if I should stay with the stock coils or go with a box and coil from MSD or maybe even just a coil. I heard stock ignition is good for up to 400hp but I'm afraid with such high compression 12.68:1 with the thicker headgasket.
Modified by LSV_REX at 9:23 AM 8/28/2007</TD></TR></TABLE>
Just stick with the stock ignition and run the correct spark plug for your engine combo. Then, get the car tuned on the dyno. You'll eventually answer your own questions/doubts about needing an ignition box.
Old Aug 29, 2007 | 08:11 AM
You can control a single stage through crome pro that will both activate the nitrous off TPS and retard timing at the same time. I have more than one stage though and it's just easier to use all MSD components to remove additional timing when another stage comes on.
Plus Scott from P.I.G. paid for all of it for me so why turn down free parts that work great for the intended purpose
Old Aug 29, 2007 | 08:29 AM
mar778c's Avatar
Community Builder
Good deal, thanks for the explaination.
Old Aug 29, 2007 | 08:30 AM
servion's Avatar
I ran my stock ignition to 9500 rpm's, 10.4 @ 140 2-3 years ago. I am a firm believer in a fresh OEM ignition system. I've since upgraded to individual coils using the autronic 500r. That is much nicer
ricekiller1
Jul 8, 2006 01:05 PM
GSR4U2NV
May 12, 2006 05:49 AM
ATS*Mark
Jan 31, 2005 08:11 PM
Charlie Moua
Mar 23, 2004 05:13 AM
