low oil pressure
Old May 10, 2003 | 05:36 PM
bey's Avatar
bey
Default low oil pressure
when i start up my car.. the oil jumps to bout 40psi.. after the car warms up.. it drops way low... lower then 10 psi at idle..... can anyone tell me whats going on with my car.. its a turbo d16 z6
Old May 10, 2003 | 08:34 PM
Blaze45's Avatar
Brrraaaap!
Default Re: low oil pressure (bey_xiong)
where is your oil press sensor placed @? Are you leaking any oil? Does anything happen when you rev it up/cange w/ psi? How many miles are on the motor? Could be an oil pump.
Blaze
Old May 10, 2003 | 11:32 PM
Sonny's Avatar
Make sure the bottom of your oil pan isn't smashed or collapsed. You can block the pickup tube's access to the oil and cause pressure problems.
Sonny
Old May 11, 2003 | 04:36 PM
bey's Avatar
bey
uhmmm... i don't know where my oil pressure sensor is.... and i'm not leaking oil...... when i rev it.. it goes up to 40 or so psi... motor only has about 60k on it..
Old May 11, 2003 | 04:40 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (bey_xiong)
you didnt install the sensor for the gauge? what engine does it have? I have herd the b16s run up as high as 75psi. As long as it moves up when you give it gas, then you should be ok. I have herd that FI cars need up to a quart more of oil depending on how long your oil lines are. Post in there and see what they say.
Blaze
Old May 11, 2003 | 04:49 PM
bey's Avatar
bey
my auto meter oil pressure came with just the fittings and that plastic line... before.. the oil pressure went up to around 70 or 80 when i start up..but now it doesn't get that high anymore.... also..my car idles at 700rpm... i can't turn it up any higher than that.. .. the screw is turn all the way and its still around 700 to 800rpm only.. and my oil is very full.. this problem never happend before until bout 2 months ago...
Old May 11, 2003 | 05:46 PM
sspikey's Avatar
Default Re: low oil pressure (Sonny)
yup check pan as someone said. stupid but often overlooked. change your oil filter and oil. if the gauge location is ok and nothing is leaking. if the problem isnt fixed. take off the pan and make sure your strainer isnt clogged. is your idle oil press ok? if its good at idle and bad at higher rpm you have a small restriction somewhere. if its just always bad you pickup or something is bashed in. change filter and oil first though please.
Old May 11, 2003 | 08:36 PM
4doortypeR's Avatar
It could be a indication that the Bearings are Going.
RemerLex11
May 15, 2005 02:35 PM
boosted_zc
May 31, 2004 09:54 AM
vtec.dc2
Feb 1, 2004 10:49 AM
black2kgsr
Jun 18, 2003 07:03 PM
