car won't idle...
Old May 9, 2003 | 09:53 PM
bxsi's Avatar
Default car won't idle...
ok so after working out some oil and coolant leaks i finally crank my bitch up and had it running for a few 5 min intervals. The car will only run with me controlling the gas pedal, and as soon as i let off it stalls. I was running my ob2 b16 ecu ( i need a basemap burned for my hondata) The only engine codes i threw were code 54 (crank. fluck. sensor) and code 6 (low coolant). The code 54 makes sense to me cuz i am running a obd 1 block with my obd 2 head and the obd 1 block doesn't use a cfk sensor.
so anyway, why can't i get this thing to idle?
off the top of my head i am guessing i might have the injector harnesses wrong, or because of the code 54... anyone else have any guesses..thanks
Old May 15, 2003 | 05:44 AM
bxsi's Avatar
bump... car still won't hold idle, injector harnesses are in correctly as well as ignition wires. Is it possible to put the distributor in a 180 degrees the wrong way, could this be the possible cause?
Old May 15, 2003 | 07:58 AM
pills_PMD's Avatar
Default Re: (bxsi)
what kind of hondata system are you using?
http://www.hondaswap.com/~pills/idlefix.html
that's a small list of the things that helped me fix my fluctuating idle
Old May 16, 2003 | 05:36 AM
bxsi's Avatar
Pills i have a p72 hondata 2b, only problem is that i'm not running it yet. I am running my stock obd 2 00' si ecu until i break in the motor and bring the hondata to get tuned. I can get the car to idle, but i have to adjust it almost everyday depending on the change in weather. BTW my hondata is used and the last base map is for a h22 turbo w/ 850cc injectors. I have a 00' b16a2 head, 94' b18c1 block sleeved w/ forged internals, jrsc @ 6-7 psi
Jay Jackson
Apr 28, 2013 10:36 AM
reed857
29
Jul 26, 2009 10:57 AM
B18CUL8R
Mar 24, 2007 03:05 PM
Austin
Sep 9, 2002 12:10 PM
