Old Apr 6, 2015, 09:32 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
black smoke coming out exhaust
Old May 9, 2003 | 03:45 PM
rtw118's Avatar
Default black smoke coming out exhaust
well my bf was driving behind me the other day and he told me that there was black smoke coming out of my exhaust.
i assume this is a problem.
he thinks it may be from using oil thats too thin and it somehow slipped into the pistons and burned up in there. i think we used 5w-30 and i read somewhere that 5w-20 is recommended for 6th gens.
what else would cause this kinda thing to happen?
Old May 9, 2003 | 04:23 PM
Stripped Honda's Avatar
99-0104
Default Re: black smoke coming out exhaust (rtw118)
5w 30 is actually a thicker oil then 5 w 20 if it were oil bruning it wouldnt be black smoke it would be blueish grey..... what are your mods
Old May 9, 2003 | 04:30 PM
rtw118's Avatar
Default Re: black smoke coming out exhaust (Stripped Honda)
no mods, its just a stock '99 v6
Old May 9, 2003 | 05:58 PM
GZERO's Avatar
how is your air filter? dirty?
Old May 9, 2003 | 08:24 PM
NiSMoCHiCK's Avatar
Default Re: black smoke coming out exhaust (GZERO)
black smoke would indicate that your car is running too rich.
try cleaning or replacing your air filter.
if it still persists, there could be something wrong with your injectors. In that case, run an injector cleaner through.
If that doesn't fix it, then you may consider having it looked at by a mechanic
Old May 9, 2003 | 09:29 PM
Nick M's Avatar
Default Re: black smoke coming out exhaust (nismopar)
blue = smoke
black = fuel
white = coolant
Old May 10, 2003 | 07:18 AM
YeuEmMaiMai's Avatar
Default Re: black smoke coming out exhaust (Nick M)
i thought it was blue = oil ehehehe althoguh blue = smoke works.........
Old May 10, 2003 | 07:21 AM
I would check your O/2 sensors
Old May 10, 2003 | 09:43 AM
-RedneckDave-'s Avatar
Working
I would bet money that it is your o2 sensors because my brothers prelude did that until we whanged his o2 sensors and it fixed the problem.
Old May 10, 2003 | 04:31 PM
Razor's Avatar
Default Re: black smoke coming out exhaust (01accordv6)
reset the ECU, let the computer reset the new air/fuel curve.
Old May 11, 2003 | 08:40 PM
rtw118's Avatar
Default Re: black smoke coming out exhaust (Razor)
its actually blueish smoke coming out, not black
maybe the seals aren't sealing so well anymore?
Old May 11, 2003 | 10:02 PM
99-0104
then your probally burning oil if it is blue smoke.... that is the first v6 that i have heard of having problems....
Old May 12, 2003 | 06:18 AM
jweller's Avatar
does it do it all the time, or just when you are hammering on it? cause if it only really smokes when you are in High RPMs that pretty much normal.
joehonda1129
Nov 29, 2007 02:35 PM
SlammedBlackGSR
Jul 6, 2006 10:55 AM
suckanut
10
May 14, 2005 04:10 PM
egracer44
23
Oct 3, 2003 06:25 AM
Lsubball99
Aug 10, 2002 01:07 PM
