what should be replaced pre swap?
hoses, maybe some lines depending on their condition, bolts, brackets, etc. For the most part you covered what you really need to do... OH dont forget the drain fluids.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitehatch11 »</TD></TR><TR><TD CLASS="quote">what should i replace before swapping a b16 into my hatch?
i'm thinking belts, timing belts, spark plugs, plug wires..., maybe clutch, anything else?</TD></TR></TABLE>
I am in the process of my swap, and i replaced timing belt, water pump, clutch, flywheel (cuz i wanted light weight one but u can get yours resurfaced), tranny fluid, oil, oil filter, and coolant. Might want to have some brake fluid around for if you have to swap out your clutch slave cylinder.
gobblebox59
45
Apr 12, 2004 06:56 PM
stripes777
Mar 18, 2004 09:09 PM
