D16y7 to D16y8 swap .. please help
Old May 4, 2003 | 06:54 PM
dubniK's Avatar
Default D16y7 to D16y8 swap .. please help
I've tried a search, but please direct me to the right link if I missed it.
I'll be doing a D16y8 swap into my 97 dx tomorrow, and wanted to know if there was some links/websites that showed this process step by step.
Also, does anyone know if my y7 header/o2 sensor will be the same on the y8?
Thank you very very very much
Old May 21, 2007 | 10:15 AM
EE_Chris's Avatar
Default Re: D16y7 to D16y8 swap .. please help (dubniK)
The header is not the same. Are you using a Y8 ECU too? You'll probably have issues with the IACV, VTEC and KS wiring.
Old May 21, 2007 | 11:33 AM
builthatch's Avatar
MiG-21 superfan
Default Re: D16y7 to D16y8 swap .. please help (EE_Chris)
a header that worked for a y7 should indeed work for a y8. the pan clearance might be looser, but it'll work.
as chris said, you have to address the KS, IACV and vtec stuff. There is a ton of info about this available, but the short version is-
p2p ecu needs a two wire iacv, so put a two wire iacv on the manifold, use the y8 TB, and do the pin swap detailed at the lower portion of this graphic-
after you do what's on that diagram, you will ahve an extra wire going into the cabin in your harness left over from the iacv deal, i ended up pinning that as one of the wires that would've had to been added for the vtec engine- knock sensor, vtec pressure or vtec activation. gave me one less wire to run. if you are running a p2p y8 ecu, you will need to add pins to the cabin plugs for the ecu in the appropriate spots for the extra ****...
Old May 21, 2007 | 07:17 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: D16y7 to D16y8 swap .. please help (builthatch)
if you plan on using the Y8 exhaust manifold you will have to extend the O2 wiring. Run wiring for the knock sensor, vtec pressure switch, vtec solenoid, and 2 wire IACV. PM or email me for any help
Lasty K
27
Nov 1, 2017 09:03 AM
byarbroo
10
Dec 3, 2012 09:40 PM
RiTtEk401
Oct 23, 2011 06:12 PM
jdmeg6r13s
Jul 30, 2010 08:52 AM
AGENT 99
25
Sep 15, 2004 09:00 AM
