gauge installation which wire to tap?
Old May 2, 2003 | 10:06 AM
ash.zero's Avatar
Default gauge installation which wire to tap?
ok, last night i finally drilled a hole in a firewall.
i'll be installing boost, egt and af (all autometer cobalt series).
which wires do i need to tap? i was thinking about using cig lighter wire as +5v IGN. any ideas?
oh, the car is 99 accord 4cyl 2dr. thanks.
Old May 2, 2003 | 11:16 AM
ash.zero's Avatar
Default Re: gauge installation which wire to tap? (ash.zero)
come on ppl...gotta start installing in 2 hours!!! >_<
Old May 2, 2003 | 11:42 AM
highmilehatch's Avatar
If you want the guages to luminate when you turn the factory lights on, run the light power wires for each guage to something like the hazard switch. I'm at work so I can't tell you exactly which color wire it is. For the air/fuel guage you can run that to the cig lighter although I've had wierd occurences of that particular guage losing all power when I'd push in the lighter, until it popped out. Instead, you could tap the 12v ignition under the steering column which would be one of the same wires you tap a turbo timer too. Good luck.
Old May 2, 2003 | 11:48 AM
ash.zero's Avatar
Default Re: gauge installation which wire to tap? (highmilehatch)
anybody know which wire is the ignition under the steering column?
thanks!
Old May 2, 2003 | 11:50 AM
boosted_dc2's Avatar
for ignition you need to tap on to the black/yellow on your ignition harness. Its a big 10 guage wire running up your steering column. for parking lights you need to find a red/black pretty much any where behind the das (at dimmer switch). and for air/fuel youll need to go to autometer.com and look up the color. i think you need to connect your purple wire to a white/some color at the computer. just go to that site and they can tell you
Old May 2, 2003 | 11:59 AM
ash.zero's Avatar
Default Re: gauge installation which wire to tap? (hooked_up_gsr)
NICE!
now i can print this post from my work and head home! i'm pretty much done with turbo installation which freaking took me 1 week to complete!!
now, only if my stupid drag4 dp was lil longer and had flange for my cat, i would be done today!
check out this stupid dp
i guess now i can spend tomorrow driving open dp looking for exhaust shops in nova area...fantastic~
jeffk182
Jan 5, 2007 07:08 PM
tyflip2
Jun 14, 2004 03:08 PM
tyflip2
May 26, 2004 06:53 AM
4doorex
Audio / Security / Video
Feb 21, 2004 04:58 PM
killa_lude
Nov 19, 2003 01:32 PM
