Turbo Timer install - 93 civic
Old May 2, 2003 | 04:28 AM
Hybrid's Avatar
Default Turbo Timer install - 93 civic
I have this turbo timer, generic brand that I want to install.
wires:
red (12v)
black (-)
green (?)
blue (?)
couple of other ones for the hand brake I'm assuming.
Can some one tell me where the green and blue go. I know they are ignition power and accessory power, but which is which, and what color wires am I looking for under the steering column.
And do I need to hook up the wires for the parking brake also, or can I just leave them?
Cheers.
Old May 2, 2003 | 06:36 AM
Spudddy's Avatar
heres wiring for a greddy turbo timer.. prob the same for every other timer
red = 12v
black = ground
blue = acc
green = start
Old May 2, 2003 | 07:26 AM
Hybrid's Avatar
Default Re: (Spudddy)
thanks man.
Old May 2, 2003 | 07:32 AM
Poop111444's Avatar
Default Re: (Hybrid)
I did my HKS one last nite. For the parking brake wire, at your ebrake there is one wire running to it on a little clip. I tapped into that wire.
Old May 2, 2003 | 08:18 AM
joeski's Avatar
Default Re: (si_mekanik)
`to things if u want u dont need to hook up the acc line and if u dont wana hook up the e brake line u can jus ground that line with the actual ground and it will work fine look for a gree wire under the sterring colom for the ignition
Psychoteen101
Audio / Security / Video
May 12, 2009 08:43 AM
B18del-turbo
Mar 31, 2005 09:27 AM
skyman88
Jul 19, 2004 11:32 AM
TURBOED-TEG
Sep 2, 2002 07:08 PM
Flamenco-T
Nov 6, 2001 06:54 AM
