turbo timer install
Old Mar 17, 2005 | 05:23 AM
B18del-turbo's Avatar
Default turbo timer install
i have a moto sports type r turbo timer going into a 94 del-sol, it has a harness with a red, blue, and yellow wires on it. i dont know witch of the five wires in the ignition to hook it up to. it has a brown wire witch gos to the e brake and a ground wire. just need to know the red,blue and yellow wires. thanks
Old Mar 17, 2005 | 06:03 AM
siblueg's Avatar
Default Re: turbo timer install (B18del-turbo)
look for lighting motorsports on honda-tech
Old Mar 24, 2005 | 04:57 PM
mike93eh
Guest
Posts: n/a
did you find your answer because i have the same timer and i know where they go.
Old Mar 28, 2005 | 05:04 AM
Default Re: (mike93eh)
no i didnt, how did u hook yours up?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">did you find your answer because i have the same timer and i know where they go.</TD></TR></TABLE>
Old Mar 28, 2005 | 11:09 AM
crx-neo's Avatar
I just hooked up my Turbo Timer the day before yesterday and it took forever with my alarm getting in the way.
Red should be main power(tester lights with no key in ignition)
Blue should be ignition(tester light on with key in Run (3rd) position only)
and Yellow should be accessory, the hard one. Should light up with key in first position (where you would listen to your stereo).
Run your ground, and tap into your ebrake line. DON'T CUT IT!.
Keep the first three up under the steering column.
I tapped into all of my lines rather than cutting them. Use a soldering gun to ensure a good connection. Be sure to tape up all exposed metal. Keep it neat and clean because you might want to remove it later.
Tools you'll need:
12 Volt wire tester, I used a needle/pen style with a light on top
Electrical tape
exacto/sharp knife or wire strippers if you have them
soldering gun, solder, power source
zip ties
A helping hand, patience
have fun!
Old Mar 29, 2005 | 07:57 AM
Default Re: turbo timer install (crx-neo)
so i hook it up and the timer starts the count down but the car turns off befor the count down begins, what the ****, help
Old Mar 29, 2005 | 09:38 PM
Evo-man@20psi's Avatar
Maybee the wrong wire to ignition
Old Mar 30, 2005 | 05:11 AM
Default Re: turbo timer install (Blue00vtecsi)
can some one give me the coller wires i need to hook the acc and the ignition wires to on a 94 delsol
Old Mar 31, 2005 | 09:27 AM
crx-neo's Avatar
Hey, try IMing mike93eh he said he has the same timer, and a 93 Civic should have the same ignition wiring as the Del Sol. He said he knows where they go.
"...i know where they go." mike93eh
Ek4 life
10
Nov 16, 2008 01:33 AM
team2dcrx
Feb 25, 2008 07:22 PM
crxvtecturbo
Jan 22, 2005 03:26 PM
Hybrid
May 2, 2003 08:18 AM
