greddy turbo timer install
Old Nov 5, 2001 | 03:42 PM
Flamenco-T's Avatar
Default greddy turbo timer install
I a 98 GS-R and a greddy turbo timer...
there are four wires
red
green
blue
black
can anyone tell me which wires I need to tap on the vehicle itself ?
like red is 12V constant, I can tap it into any power source, it's the 12V ignition and accesories is what I need to know...
TIA
Old Nov 5, 2001 | 05:31 PM
dustin's Avatar
Default Re: greddy turbo timer install (Flamenco-T)
I do not remember the wire colors, but you tap into the 2 primary ignition harnesses. One has a huge white wire and that is constant 12v. The other harness has IG1 and IG2 in it. If you can source a copy of the Helm manual page, it has a diagram/picture that explains everything. You only need to hook up these 4 wires, the rest can be disconnected.
Dustin
Old Nov 5, 2001 | 06:55 PM
adam's Avatar
Take off the plastic covers that are on the steering column and the ignition barrel is labeled on the opposite side of the keyhole (black plastic end).
Old Nov 5, 2001 | 07:13 PM
SagaGSR's Avatar
Default Re: greddy turbo timer install (adam)
be sure to get a proper wire tap for that huge white wire. i used a 14-10 gauge wire tap and it still becomes loose
Old Nov 5, 2001 | 07:41 PM
GSRrR's Avatar
make sure u don't twist the wires coming out the back of the timer in a weird way . i did and my timer acts up sometimes. This is my second timer after the first one stopped working with my alarm (the car would not arm anymore). Yes i did add a relay and it was working for a week. It just stopped working one day.
Old Nov 5, 2001 | 11:44 PM
dustin's Avatar
Default Re: greddy turbo timer install (GSRrR)
I soldered into the wires, wire taps suck.
Dustin
Old Nov 6, 2001 | 03:23 AM
JM Performance's Avatar
Default Re: greddy turbo timer install (dustin)
Dustin
What sucks about them?
Old Nov 6, 2001 | 05:59 AM
VTC_CiViC's Avatar
Ditto
Wire taps don't always make the best connection, and can come loose. Never had a problem with anything I've soldered into my Civic including the A/F gauges, AVC-R, V-AFC and timer.
Old Nov 6, 2001 | 06:43 AM
adam's Avatar
Default Re: greddy turbo timer install (SagaGSR)
I took my pocket knife, cut off some of the sheathing of the white wire, stripped a lot off of the red power wire for the turbo timer and wrapped it around the exposed white wire. Then electrical taped the whole thing. Works well.
Old Nov 6, 2001 | 06:54 AM
dustin's Avatar
Wire taps come loose. When I had my V-AFC, I was stranded twice because the apex wire taps came loose off the power wire.
Dustin
Psychoteen101
Audio / Security / Video
May 12, 2009 08:43 AM
HamiltonRex
14
Aug 9, 2006 06:07 PM
turbob16a522
Jul 3, 2005 08:49 AM
underpressure02
Sep 28, 2004 08:08 AM
wickedxboi
Oct 24, 2003 01:56 PM
